I haven’t tried to lower it because I don’t want to spam the Unifi Controller with requests. Maybe someone else has trimmed that parameter and can share experiences
It also depends on how fast the Unifi Controller software refreshes its own info… I don’t know the answer to this
Just tested it out. It took 21 seconds after I arrived at the door. Phone normally has WiFi before I arrive at the door. So, it is not usable for disabling alarm.
It really depends on how fast the Unifi Controller software will update it’s own database.
The reporting to the Binding can only happen after this first step has been completed.
It may take 5-6 secs for Unifi controller to mark you as present and then another 10 secs for the binding to pull this updated info.
You can try to lower the refresh= on the bridge down to 1 sec
Just to be clear: I am not blaming the Binding. My hopes were not that high anyway, that this could work for my use-case because timing would be really critical.
another “workaround” would be to increase a bit the entry delay on your alarm system (let the PIRs trigger but not fire the alarm within a 35 secs window till disarming)
by the way: I don’t know if it’s such a great idea to automate this aspect…
think about: theft of mobile phone device prior to the burglary attempt…
I also have my alarm panel integrated in OH2 but I don’t auto-disarm. I do it manually.
I do auto-arm based on several criteria (one of which is presence)
I can only confirm that this binding works absolutely great as presence detection, I’ve tried the network/ping method before but imo there is no comparison.
Unifi doesn’t impact battery but also no glitches no missed pings or any of thos, it works flawless.
I fully agree and I use a mix of different Android and iPhone devices hopping over four UAP-AC-PRO. I’m more than impressed, how reliable it is. No false detection!
Regarding presence of wired devices - couldn’t this be done through the snmp binding and checking ifOperStatus of the port you’re interested in? Or are we talking about clients connected to cascaded switches?
Of course it can be done with snmp
But I believe that Matthew is planning to implement this feature in the binding as well
I haven’t tested if it works now as is.
From what I remember, the Unifi Controller reports wired clients as well
if there is no direct connection to the remote network I do not see how the snmp binding will work… How do I get from the controller subnet to the remote subnet if there is no routing?
remote network does not mean no routing maybe you wanted to write “isolated network” or something similar
of course you need routing in place for the snmp to work
if using cascaded switches (only Layer 2 links) you could face a problem
I guess its down to my English I have a controller at home and about 15 different sites scattered around Europe. I would call them remote, because they are not really isolated. Anyway there is not direct routing from controller subnet to the “isolated” subnets.
