2018-12-06 20:54:31.669 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'unifi.things'
2018-12-06 20:54:32.756 [ERROR] [.handler.UniFiControllerThingHandler] - Unknown error while configuring the UniFi Controller
org.openhab.binding.unifi.internal.api.UniFiException: java.lang.RuntimeException: No Common Name found
at org.openhab.binding.unifi.internal.api.UniFiControllerRequest.getContentResponse(UniFiControllerRequest.java:157) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.api.UniFiControllerRequest.getContent(UniFiControllerRequest.java:117) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.api.UniFiControllerRequest.execute(UniFiControllerRequest.java:102) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.api.UniFiController.executeRequest(UniFiController.java:113) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.api.UniFiController.login(UniFiController.java:70) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.api.UniFiController.start(UniFiController.java:56) ~[190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.openhab.binding.unifi.internal.handler.UniFiControllerThingHandler.initialize(UniFiControllerThingHandler.java:117) [190:org.openhab.binding.unifi:2.4.0.201812061741]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:208) [108:org.eclipse.smarthome.core.thing:0.10.0.oh240M7]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh240M7]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh240M7]
Caused by: java.lang.RuntimeException: No Common Name found
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1519) ~[?:?]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:528) ~[?:?]
at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:802) ~[?:?]
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:766) ~[?:?]
at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:681) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:128) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:155) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) ~[?:?]
... 1 more
Caused by: java.lang.IllegalStateException: No Common Name found
at org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManager.getCommonName(ExtensibleTrustManager.java:157) ~[?:?]
I’m going to touch on both of the issues that have been reported:
[1] Circular reference detected
The error looks like this:
!ENTRY org.apache.felix.scr 4 0 2018-12-07 06:55:13.806
!MESSAGE Circular reference detected trying to get service {org.eclipse.smarthome.io.net.http.TlsTrustManagerProvider}={service.id=62, service.bundleid=4, service.scope=bundle, component.name=org.openhab.binding.unifi.internal.ssl.UniFiTrustManagerProvider, component.id=26}
stack of references: ServiceReference: {org.eclipse.smarthome.io.net.http.TlsTrustManagerProvider}={service.id=62, service.bundleid=4, service.scope=bundle, component.name=org.openhab.binding.unifi.internal.ssl.UniFiTrustManagerProvider, component.id=26}
ServiceReference: {org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManager}={service.id=69, service.bundleid=107, service.scope=bundle, component.name=org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManager, component.id=29}
What I think is happening:
UniFiThingHandlerFactory depends on a reference to HttpClientFactory
HttpClientFactory depends on ExtensibleTrustManager
ExtensibleTrustManager depends on TlsTrustManagerProvider (provided by unifi) <-- circular reference
@martinvw Going to need your input here as you were involved with the TlsTrustManagerProvider interface
Regardless of this error, it seems that it eventually loads everything and the binding functions as expected.
[2] java.lang.RuntimeException: No Common Name found
@roryd This looks like an issue with your SSL certificate. How are you running the UniFi controller (docker, cloud key, raspberry pi)?
The latest version of the binding expects to see the common name property of the SSL certificate as UniFi and the error seems to be saying there is no CN property in your SSL certificate or it’s blank.
Since the controller is a bridge, I really don’t think it should have any channels. What about if we added a site thing that included a handful of “client count” channels:
Sounds cool. I have just checked the few bridges in my system (hue, netatmo and somfytahoma, and none of them have channels of their own, so a “site” thing seems to be the way to go.
What if you wanted to track the number of clients for siteA and siteB? If these channels were on the controller (where the site parameter would be defined), you could only track one site.
Because that’s the default generated CN by the controller. If you were to import a valid certificate from a trusted CA (say from Let’s Encrypt), then Java’s built-in trust management would kick in and everything would still work. Just because the binding is expecting CN=UniFi doesn’t mean that’s the only SSL cert it would accept.
@kai requested that I try and make use of the common HttpClient instance provided by the framework. However, since the default SSL cert in the controller is self-signed, it’s a bit tricky to get the framework to accept the SSL cert.
2018-12-07 12:14:27.248 [vent.ItemStateChangedEvent] - MatthewsPhone changed from OFF to ON
2018-12-07 12:14:27.249 [vent.ItemStateChangedEvent] - MatthewsPhoneSite changed from UNDEF to [redacted]
2018-12-07 12:14:27.251 [vent.ItemStateChangedEvent] - MatthewsPhoneMAC changed from UNDEF to [redacted]
2018-12-07 12:14:27.252 [vent.ItemStateChangedEvent] - MatthewsPhoneIP changed from UNDEF to [redacted]
2018-12-07 12:14:27.253 [vent.ItemStateChangedEvent] - MatthewsPhoneUptime changed from 0 to 8387
2018-12-07 12:14:27.268 [vent.ItemStateChangedEvent] - MatthewsPhoneLastSeen changed from NULL to 2018-12-07T12:14:20.000+0200
2018-12-07 12:14:27.268 [vent.ItemStateChangedEvent] - MatthewsPhoneAP changed from UNDEF to [redacted]
2018-12-07 12:14:27.269 [vent.ItemStateChangedEvent] - MatthewsPhoneESSID changed from UNDEF to [redacted]
2018-12-07 12:14:27.269 [vent.ItemStateChangedEvent] - MatthewsPhoneRSSI changed from UNDEF to 29
strange. I have been monitoring the state of my Items using the console and doing items list "grep -i unifi and their state hasn’t updated since I used the newest version of the binding
do you get the Circular reference also or not?
Note: I may be wrong but I remember the following: The first time that I started it, it looked ok and I didn’t get any Circular reference logged. I stopped OH2 service, error appeared, started again… error again and since then: no updates
I will enable TRACE to see what is going on and report back
It’s perfectly ok for a bridge to have channels. Having said that, I agree it would be better to have separate Thing(s) for the site(s). As you said, there’s greater flexibility for defining multiple sites.
I just restarted OH2 service and got immediately (first 2 entries in openhab.log) the Circular reference error (1st) from org.apache.felix.scr and the ServiceException warning (2nd) from org.openhab.binding.unifi
So far: no updates from the binding to my Items (no worries: we are testing stuff out )
try to restart the OH2 service on your S1451 testbed system to see if they come up
