today i wanted to try openHAB 2. After installing java8 i installed openHAB 2 as described in the installation guide. I chose the stable build. Everything went well and after a restart openHAB is running, but i am not able to open portal with http://openhab-device:8080 nor my_ip:8080
Hello, we have chosen “openhab-device” as a dummy name at this point of the documentation. On other sites you might see something like “http://your-ip-address-or-dns-name-here:8080”
Would something like this snippet from another site be better?
Kibana is a web application that you access through port 5601. All you need to do is point your web browser at the machine where Kibana is running and specify the port number. For example, localhost:5601 or YOURDOMAIN.com:5601.
To confirm that there is something “listening” for requests, you can execute from the command line
netstat -nl4 | fgrep LISTEN
The n argument provides numeric output, l is to include listening sockets (ones that are listening for connections, but aren’t connected yet) and the 4 says to only list IPv4. The | fgrep LISTEN just trims the output to listening sockets.
If openHAB is up and running, ready for connections, you’ll see a line that looks like:
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN
The 0.0.0.0 means “any” in terms of addresses on your machine (third column), as well as for hosts that connect (fourth column).
