Should maven perform cleanup on the UI packages? I’m thinking remove node, node_modules, and bower_components.
Thoughts?
Thoughts?
This is probably rather a question for https://www.eclipse.org/forums/index.php/f/271/, since there are no such packages in openHAB itself, right?
But in general: Yes, this sounds as if it makes sense.
