I have a lot of devices in my Paper UI Inbox but no idea if those are actually my sensors.
Is there a way I can check the data of these items before actually creating an Item for every value and displaying it in the UI? If it’s not one of my sensors I don’t want to add it.
I know that those are not my devices, the range of my 433/868mhz sensors is quite high and many of them are discovered by the rfxtrx - but anyway, my question is how to see the data before creating an item.
As far as i know, you can’t see the values before adding the things from the Inbox.
You may make your life easier if you enable simple link. Then the items will be created automatically in the jsondb and you may review them with PaperUI.
hmmm - but the item name is not editable if automatically generated, right?
now I’ve got names like: “HG-HM-CC-TC:17b78d3e:HEQ0133009” in my influxDB which are difficult to handle
You are not able to identify your Homematic devices? You can’t see other ones than those which are connected to your bridge. The Homematic devices are easily identifiable. Just look at your bridge (CCU, Homegear or whatever).
It’s no problem to identify them, but it’s a mess to handle the cryptic IDs in different components such as postgres, influx, etc as you need a mapping everywhere. Would be easier with a readable name.
