hmerk
(Hans-Jörg Merk)
November 16, 2020, 1:24pm
#1
I am trying to create a custom widget, but cannot get coloring of an icon based on an item state to work.
YAML extract:
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
slots:
default:
- component: oh-button
icon-f7: arrow_2_circlepath
iconColor: '=(items.acAttic_Mode.state === "AUTO") ? "red" : "grey"'
text: Auto
@RGroll @ysc Any clue, why this does not work ??? Hardcoding the color works fine.
Next question, how to get the text below the icon ???
RGroll
(Rainer)
November 16, 2020, 2:58pm
#2
Just a typo in the ‘gray’ color value - everything else works fine on my side.
Only ‘gray’ is supported as a color-theme in f7 (see here )
It seems that ‘gray’ is a more common spelling in the US while ‘grey’ is used in other english-speaking countries (in css both values work - not here obviously.) - Grammarly article on that
iconColor: '=(items.testItem.state === "AUTO") ? "red" : "gray"'
text: Auto
tl;dr: This isn’t natively supported by the f7-/oh-button component (yet?!).
You could do that with something like this - but it might destroy the layout on mobile devices and you can’t use the button-fill class here, as it has a higher z-index than it’s slot components. There might be a workaround for that with some tinkering.
- component: f7-col
class:
- button
- color-gray
style:
height: 55px
slots:
default:
action: SOMETHING
class:
--f7-button-bg-color: transparent
--f7-button-hover-bg-color: rgba(var(--f7-theme-color-rgb), .07)
--f7-button-pressed-bg-color: rgba(0,0,0,.15)
style:
position: absolute
top: 0
left: 0
width: 100%
height: 100%
z-index: 999
- component: f7-icon
color: '=(items.testItem.state === "AUTO") ? "red" : "gray"'
- component: Label
text: Auto
style:
color: black
hmerk
(Hans-Jörg Merk)
November 16, 2020, 3:02pm
#3
Dumb me
Thanks Rainer !!!
According to second question, I will give it a try…
ysc
(Yannick Schaus)
November 16, 2020, 4:05pm
#4
I’m adding a default slot to the oh-button & oh-link so you’ll be able to put anything inside the button:
style:
height: auto # height is fixed with var(--f7-button-height)
slots:
default:
style:
display: block
- component: Label
text: Test
For now you can configure the button like this:
class:
- margin
- display-flex
- flex-direction-column
style:
height: auto
The text will be off the icon by 4px and that’s not fixable with this approach currently.
hmerk
(Hans-Jörg Merk)
November 16, 2020, 4:09pm
#5
Thanks Yannick, excellent as usual !!!
system
(system)
closed
December 28, 2020, 8:09am
#6
