- Platform information:
- Hardware:Intel® Core™ i7-10700 CPU @ 2.90GHz × 16
- OS: linux ubuntu 18.04.6
- Java Runtime Environment: openjdk version “11.0.19” 2023-04-18
- openHAB version:openhab 3something to openhab 4.0.0
- Issue of the topic: I just try to update my openhab server and at the end I can not acces to http://localhost:8080/ in my log http://localhost:9001/ page I find this message
2023-08-18 11:18:54.021 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature; version="[4.0.0,4.0.0]"; filter:="(&(osgi.identity=openhab-runtime-base)(type=karaf.feature)(version>=4.0.0)(version<=4.0.0))" [caused by: Unable to resolve openhab-runtime-base/4.0.0: missing requirement [openhab-runtime-base/4.0.0] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.0: missing requirement [openhab-core-base/4.0.0] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version="[4.0.0,4.0.0]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:374) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:256) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
at java.lang.Thread.run(Thread.java:829) ~[?:?]
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-runtime-base/4.0.0: missing requirement [openhab-runtime-base/4.0.0] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.0: missing requirement [openhab-core-base/4.0.0] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version="[4.0.0,4.0.0]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]]]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-core-base/4.0.0: missing requirement [openhab-core-base/4.0.0] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version="[4.0.0,4.0.0]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"
... 12 more
And when I check the status with the command “sudo systemctl status openhab.service” I have this error message
● openhab.service - openHAB instance, reachable at http://domus-server:8080
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Fri 2023-08-18 11:18:52 CEST; 9s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 27170 ExecStop=/usr/share/openhab/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 27338 (java)
Tasks: 58 (limit: 4915)
CGroup: /system.slice/openhab.service
└─27338 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.cm.dir=/var/lib/openhab/config -Djava.li
Aug 18 11:18:54 domus-server karaf[27338]: ... 12 more
Aug 18 11:18:54 domus-server karaf[27338]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-core-base/4.0.0: missing requirement [openhab-core-base/4.0.0] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; versi
Aug 18 11:18:54 domus-server karaf[27338]: at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341)
Aug 18 11:18:54 domus-server karaf[27338]: ... 13 more
Aug 18 11:18:54 domus-server karaf[27338]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.ope
Aug 18 11:18:54 domus-server karaf[27338]: ... 14 more
Aug 18 11:18:54 domus-server karaf[27338]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"
Aug 18 11:18:54 domus-server karaf[27338]: ... 15 more
Also I can not acces to the openhab console by using the command openhab-cli console
openhab-cli console
Logging in as openhab
Failed to get the session.
I found other topic but no one with the same error. I would like know if I should downgrade my OH? If yes, How, and what version can I choose? If no what I should do?
Merci à tous ceux qui pourraient m’aider
