I am running a docker container 2.5.M1.
I have migrated all of my files and configs from an Opehabian install which worked reasonably trouble free.
Main issues were:
missing libraries (ffmpeg), the exec binding (permissions and file path changes) and getting configs redirected to new docker containers for InfluxDB / mosquitto etc.
Irrespective, I am very happy with the progress so far, but have come across a bit if a problem.
I am presenting openhab on port 8888 - so my port number os not the default (I am not sure if this is related, just thought I would include it in case there is some ugly hard mapping)
When I attempt to access any content in the /static folder (i.e. http://openhabhost:8888/static) I getan error message:
## HTTP ERROR 404
Problem accessing /static. Reason:
Not Found
[Powered by Jetty:// 9.4.12.v20180830](http://eclipse.org/jetty)
When I access this in my old instance, I get:
# openHAB user provided static content
Serve your own static html pages or resources from here. Files stored in the openHAB configuration subfolder html will be available through the HTTP server of openHAB, e.g. http://device-address:8080/static/image.png.
Resources for sitemap elements (image, video,...) can also be provided though this folder.
It seems that this is rendering incorrectly - and I have no idea if this is due to a config I copied over from my openhabian install, or something related to the port change.
Could you share your Dockerfile (and if used your docker-compose.yaml) and an ls -al of the html directory? My guess it is related to the volume mapping of the container for this directory or a file access issue.
