I am new to openHAB. I am executing openHAB in my linux desktop which has Intel CPU.
I have followed manual steps to install and access openHAB dashboard. , created separate folder for openHAB source and followed below steps,
Steps followed,
Installed Zulu in my ubuntu 16.04
Downloaded and Installed “openhad-distro” from this https://bintray.com/openhab/mvn/openhab-distro .
Downloaded “openhab2” from this https://bintray.com/openhab/mvn/download_file?file_path=org%2Fopenhab%2Fdistro%2Fopenhab%2F2.3.0%2Fopenhab-2.3.0.zip
Run ./start.sh and got openhsb commad prompt.
I have tried to access openHAB dashboard by giving this address 10.1.68.206:8080 (my system ip) in browser.
I am not getting openHAB dashboard, instead I am getting jenkin login page.
Can you please help me to access the openhab dashboard? Once I can able to access openhab dashboard, It will be easy to me install it on NXP gateway.
Please correct me, If I have committed any mistakes.
thanks,
dhanasekar
H102
(CM6.5 H102)
October 26, 2018, 2:33pm
2
Did you mean the OH server address or your PC’s address? You can also try using openhab-device:8080
Have you did this
sudo systemctl start openhab2.service
sudo systemctl status openhab2.service
sudo systemctl daemon-reload
sudo systemctl enable openhab2.service
Also per the doc’s:
The first start may take up to 15 minutes , this is a good time to reward yourself with hot coffee or a freshly brewed tea!
You should be able to reach the openHAB 2 Dashboard at http://openhab-device:8080 at this point.
vzorglub
(Vincent Regaud)
October 26, 2018, 2:40pm
3
I would recommend use the apt install way rather than the manual install that you did.
H102
(CM6.5 H102)
October 26, 2018, 2:44pm
4
I agree, but I assume the OP has a reason for manual installing?
This 10.1.68.206:8080 is my PC IP address.
I have followed these steps when installing by apt method,
sudo systemctl start openhab2.service sudo systemctl status openhab2.service sudo systemctl daemon-reload sudo systemctl enable openhab2.service
It is not working.
Thanks,
Dhanasekar
H102
(CM6.5 H102)
October 26, 2018, 3:18pm
6
What is the output when you use this command?
I am unable to access the dashboard.
Hi H102,
I am getting below output, when I run “sudo systemctl status openhab2.service”
ananth@ananth:/tmp$ sudo systemctl status openhab2.service
**[sudo] password for ananth: **
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-10-30 12:35:20 IST; 1h 44min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 12662 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 12845 (java)
CGroup: /system.slice/openhab2.service
└─12845 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dope
Oct 30 12:35:20 ananth systemd[1]: Started openHAB 2 - empowering the smart home.
lines 1-11/11 (END)
Thanks,
Dhanasekar
H102
(CM6.5 H102)
October 30, 2018, 3:00pm
9
Did you install OH in the tmp directory?
Hi H102,
No, I have not installed OH in tmp directory. Can you please help me to install OH?.
FYI, I am following manual installation steps which is in this link https://www.openhab.org/docs/installation/linux.html#installation .
Please provide standard steps to install openHAB in Ubuntu 16.
Thanks,
Dhanasekar
H102
(CM6.5 H102)
October 30, 2018, 9:50pm
11
You can install manually or by using apt-get (the same as the openhabian image install for RPI). With the ubuntu version posted install using apt-get and follow the instructions. You may need to uninstall, remove and purge what’s been installed thus far and start over.
Hi H102,
I am very new to openHAB project. I have come across lot of procedures (for installing openhab in Ubunutu), I am getting confuse.
Can you please share the steps in this mail thread?.
Thanks,
Dhanasekar
I have followed below steps for installing openhab in Ubuntu 16.04 LTS Desktop,
sudo adduser --system --no-create-home --group --disabled-login openhab
cd /tmp
wget -O openhab-download.zip https://bintray.com/openhab/mvn/download_file ?
sudo unzip openhab-download.zip -d /opt/openhab2
rm openhab-download.zip
3.
sudo chown -hR openhab:openhab /opt/openhab2
sudo su -s /bin/bash -c ‘/opt/openhab2/start.sh’ openhab
5. When I enter "http://10/1.68.206:8080" in browser, I am not seeing openhab dashboard.
FYI, my Java configuration details,
**_ananth@ananth:/tmp$java -version_
_openjdk version "1.8.0_181"_
_OpenJDK Runtime Environment (Zulu 8.31.0.1-linux64) (build 1.8.0_181-b02)_
_OpenJDK 64-Bit Server VM (Zulu 8.31.0.1-linux64) (build 25.181-b02, mixed mode)_
Thanks,
Dhanasekar
Hi All,
I have pasted my “etc/default/openhab2” below and I am seeing most variables are commented.
Is it expected?.
ananth@ananth:/$ sudo cat /etc/default/openhab2
openHAB 2 service options
PORTS
The ports openHAB will bind its HTTP/HTTPS web server to.
#OPENHAB_HTTP_PORT=8080
#OPENHAB_HTTPS_PORT=8443
HTTP(S) LISTEN ADDRESS
The listen address used by the HTTP(S) server.
0.0.0.0 (default) allows a connection from any location
127.0.0.1 only allows the local machine to connect
#OPENHAB_HTTP_ADDRESS=0.0.0.0
BACKUP DIRECTORY
Set the following variable to specify the backup location.
runtime/bin/backup and runtime/bin/restore will use this path for the zip files.
#OPENHAB_BACKUPS=/var/lib/openhab2/backups
JAVA OPTIONS
Additional options for the JAVA_OPTS environment variable.
These will be appended to the execution of the openHAB Java runtime in front of all other options.
A couple of independent examples:
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0"
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
EXTRA_JAVA_OPTS="-Djna.library.path=/lib/arm-linux-gnueabihf/ -Duser.timezone=Europe/Berlin -Dgnu.io.rxtx.SerialPorts=/dev/ttyS0"
EXTRA_JAVA_OPTS=""
OPENHAB DEFAULTS PATHS
The following settings override the default apt/rpm locations and should be used with caution.
openHAB will fail to update itself if you’re using different paths.
Only set these if you are testing and are confident in debugging.
#OPENHAB_HOME=/usr/share/openhab2
#OPENHAB_CONF=/etc/openhab2
#OPENHAB_RUNTIME=/usr/share/openhab2/runtime
#OPENHAB_USERDATA=/var/lib/openhab2
#OPENHAB_LOGDIR=/var/log/openhab2
OPENHAB USER AND GROUP
The user and group that takes ownership of openHAB. Only available for init.d systems.
To edit user and group for systemd, see the service file at /usr/lib/systemd/system/openhab2.service.
#OPENHAB_USER=openhab
#OPENHAB_GROUP=openhab
SYSTEMD START MODE
The Karaf startmode for the openHAB runtime. Only available for systemctl/systemd systems.
Defaults to daemon when unset here. Multiple options can be used without quotes.
debug increases log output. daemon launches the Karaf/openHAB processes.
Hi H102,
I can able to reach OH dashboard. I have deleted all old OH source code and it’s related files in Ubuntu system . I have followed “apt-get” automatic installation procedure for OH.
with “https://10.1.68.206:8443/ ” - I can able to reach dashboard.
with “http://10.1.68.206:8080 ” - I can’t able to reach dashboard.
Can you please help me on this?
Thanks,
Dhanasekar
H102
(CM6.5 H102)
November 1, 2018, 1:59pm
16
If https works do you have something in your network that’s blocking http access?
mhilbush
(Mark)
November 1, 2018, 2:14pm
17
Dhanasekar_Jaganatha:
openhab-2.3.0.zip
The 2.3 version is really old at this point. Before you go too far with 2.3, you might want to consider starting with Milestone M5.
M4 was on Sept. 25 and 2.4.0.M5 is… NOW!
I just finished building and releasing it - so almost within one month again.
It includes a few important changes:
The newline issue in the ssh connection has been fixed.
The instance shutdown upon VS Code disconnect is solved (openHAB again keeps running)
HABot is included (the new Chatbot UI)
And here’s some more from Jenkins:
updated to 1.0.33 for new zigbee libs (detail / githubweb )
Set maven-install-plugin version to 2.5.2 (#40…
Hi H102,
I am not sure. I have to check my network. I have to debug further.
Thanks,
dhanasekar
Hi Mark,
I am using “SNAPSHOT” release and its version is 2.4.0. .
Can I still use this version or you want me to upgrade?.
Thanks,
Dhanasekar
mhilbush
(Mark)
November 2, 2018, 10:31am
20
The snapshot version is fine.
