I have contacted z-wave.me and posted on their forum but thought I should post it here as well in case someone had a similar issue.
bit hesistant to expand my zwave network without having the ability to backup razberry.
I have installed and reinstalled the software a few times but i cannot seem to get the webserver to run.
i am running
Distributor ID: Debian
Description: Debian GNU/Linux 7.8 (wheezy)
Release: 7.8
Codename: wheezy
startuplog
Z-Way version v2.1.1 from 2015-09-02 15:34:21 +0300 (build 9758c27c9115509143f3e5faaaa22f7db4dde2b5)
Looking for modules in ./modules
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modinstaller.so loaded
Module modhomekit.so loaded
Module modhttp.so loaded
Module modws.so loaded
Module modzbw.so loaded
Module modsockets.so loaded
Module modcrypto.so loaded
Module modzwave.so loaded
Module modenocean.so loaded
Module moddhs.so loaded
Using default configuration file config.xml
Error: 'debug-port' number is out of range. Skipping it.
Failed to open log file: 13
[2015-10-05 17:32:38.966] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-05 17:32:38.968] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-05 17:32:38.978] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-05 17:32:39.035] [I] [core] Executing script: /*! ...
[2015-10-05 17:32:39.079] [I] [core] Executing script: // Underscore.js 1.7.0 ...
[2015-10-05 17:32:39.125] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-05 17:32:39.131] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-05 17:32:39.169] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-05 17:32:39.178] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-05 17:32:39.181] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-05 17:32:39.184] [I] [core] Executing script: ...
reinstall log
$ sudo wget -q -O - razberry.z-wave.me/install | sudo bash
Removing MathKernel
Reading package lists... Done
Building dependency tree
Package 'wolfram-engine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
Installing additional libraries
Get:1 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Get:2 http://archive.raspberrypi.org wheezy Release.gpg [473 B]
Get:3 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Get:4 http://archive.raspberrypi.org wheezy Release [17.6 kB]
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Get:5 http://mirrordirector.raspbian.org wheezy/main armhf Packages [6,908 kB]
Get:6 http://archive.raspberrypi.org wheezy/main armhf Packages [135 kB]
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:7 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.6 kB]
Get:8 http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [49.3 kB]
Get:9 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [592 B]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 7,149 kB in 28s (254 kB/s)
Building dependency tree...
Reading state information...
gawk is already the newest version.
sharutils is already the newest version.
tzdata is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
Getting Z-Way for Raspberry Pi and installing
--2015-10-06 05:48:07-- http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.1.1.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 15865798 (15M) [application/x-gzip]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz'
100%[=======================================================================================================================>] 15,865,798 707K/s in 24s
2015-10-06 05:48:32 (640 KB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz' saved [15865798/15865798]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: done.
Making backup of previous version of Z-Way in /opt/z-way-server_2015-10-06-05-48-38
Copying settings
cp: cannot stat `/opt/z-way-server_2015-10-06-05-48-38/config/Configuration.xml': No such file or directory
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-10-06 05:48:57-- http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 401379 (392K) [application/x-gzip]
Saving to: `STDOUT'
100%[=======================================================================================================================>] 401,379 394K/s in 1.0s
2015-10-06 05:48:58 (394 KB/s) - written to stdout [401379/401379]
[....] Stoping zbw_connect:[info] ok.
zbw_connect patched
[....] Starting zbw_connect:[info] ok.
Getting webserver mongoose for Webif
--2015-10-06 05:48:59-- http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[=======================================================================================================================>] 44,749 87.6K/s in 0.5s
2015-10-06 05:49:00 (87.6 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Stopping mongoose http server
Adding mongoose to autostart
Start mongoose http server
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
zway server log
[2015-10-06 16:20:49.073] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-06 16:20:49.075] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-06 16:20:49.084] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-06 16:20:49.150] [I] [core] Executing script: /*! ...
[2015-10-06 16:20:49.194] [I] [core] Executing script: // Underscore.js 1.7.0 ...
[2015-10-06 16:20:49.242] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-06 16:20:49.250] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-06 16:20:49.288] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-06 16:20:49.296] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-06 16:20:49.299] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-06 16:20:49.301] [I] [core] Executing script: ...
[2015-10-06 16:39:03.205] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-06 16:39:03.207] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-06 16:39:03.215] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-06 16:39:03.271] [I] [core] Executing script: /*! ...
[2015-10-06 16:39:03.314] [I] [core] Executing script: // Underscore.js 1.7.0 ...
[2015-10-06 16:39:03.362] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-06 16:39:03.369] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-06 16:39:03.406] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-06 16:39:03.414] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-06 16:39:03.417] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-06 16:39:03.419] [I] [core] Executing script: ...
