I tried last night to setup OpenHab via openhabian last night for the first time. I (believe) I followed the instructions correctly and flashed a new SD card with the latest openhabian for my raspberry pi3. Everything seemed to go to plan and I can SSH into it and there are no errors in the logs etc. However when I try to go to http://openhabianpi:8080 my computer will not connect. I have tried with different browsers and also using the IP address instead. I am using a virgin media hub for my internet. I was wondering is there any setting I need to change on the PI or the hub to get this to work.
Im going to try starting again just incase but I was wondering if there is anything obvious else I should try first.
Thanks for your help and sorry for such a NOOB question…
I waited a couple of hours in the end and according to the log of the initial set up it had finished. I will check again tonight when I get in just to make sure
I’m on the same network so I assumed that would work? Have I missed something? I thought to get to the UI I just needed to go through a web browser from a computer on the same network? Thanks for your help.
Ok So I have tried formatting the SD card and reinstalling and again I can’t access the UI. Iam confident I have followed the instruction (download, flash with etcher, wait (9hrs) etc).
I can SSH into it using terminal on my mac but when try to access the UI through safari I can’t connect.
I dont think I have missed any instructions / I dont think there are any others.
Any suggestions? Im using the latest version of openhabian.
Just to make sure:
you are trying to connect to “http://openhabianpi:8080”, which can work only if you “openhabianpi” is the name of your System running openHAB. You could try that using the IP of your System instead of the name.
for further checks, can you ping the System from your mac?
