I’ve got a couple of problems with manipluating values.
I’m taking an mqtt feed from emoncms, I want to calculate Usage from import and Solar, as convert the voltage by dividing by 10.
Items:
Number PowerUsage "Use now [%d W]" (gMqtt,gPower)
Number PowerImport "Import [%d W]" (gMqtt,gPower) {mqtt="<[mosquitto:emon/emontx1/power1:state:default]"}
Number PowerSolar "Solar [%d W]" (gMqtt,gPower) {mqtt="<[mosquitto:emon/emontx1/power2:state:default]"}
Number PowerMains "Mains [%d V]" (gMqtt,gPower) {mqtt="<[mosquitto:emon/emontx1/power4:state:JS(divide.js)]"}
Rules:
rule "Calculate Usage"
Item PowerImport received update
logInfo("calculateUsage", "Calculate Usage")
if (PowerUsage.state == Uninitialized) {
postUpdate(PowerUsage, 0)
logInfo("calculateUsage", "Import: " + PowerImport.state)
logInfo("calculateUsage", " Solar: " + PowerSolar.state)
logInfo("calculateUsage", " Usage: " + PowerUsage.state)
postUpdate(PowerUsage, PowerImport.state + PowerSolar.state)
divide.js
(function(i){ return i/100; })(input)
On updates I get the following errors:
2016-12-09 06:53:04.116 [INFO ] [.o.model.script.calculateUsage] - Calculate Usage
2016-12-09 06:53:04.135 [INFO ] [.o.model.script.calculateUsage] - Import: 687
2016-12-09 06:53:04.141 [INFO ] [.o.model.script.calculateUsage] - Solar: 0
2016-12-09 06:53:04.147 [INFO ] [.o.model.script.calculateUsage] - Usage: 0.0
2016-12-09 06:53:04.159 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Calculate Usage': Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
2016-12-09 06:53:04.234 [WARN ] [o.u.i.items.ItemUIRegistryImpl] - Exception while formatting value '238.58' of item PowerMains with format '%d V': java.util.IllegalFormatConversionException: d != java.math.BigDecimal
James
