I have been using OpenHAB 2 with my Aeotec Z-Stick using ser2net
and socat
for several years. I decided to do an upgrade to 3.3.0 and went with trying out the RFC2217 option.
Unfortunately it does not appear to work, just says it’s offline. Even after rebooting all the things.
The logs on the OpenHAB server don’t seem to offer much insight into helping me determine what’s wrong:
2022-12-01 00:49:33.824 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2022-12-01 00:49:34.469 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2022-12-01 00:49:38.833 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2022-12-01 00:49:41.765 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2022-12-01 00:49:44.031 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2022-12-01 00:49:44.031 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2022-12-01 00:49:56.527 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:50:26.522 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:50:31.521 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:50:56.524 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:51:26.515 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:51:56.512 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:52:06.113 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:09a2c7c858' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2022-12-01 00:52:06.147 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:09a2c7c858' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-12-01 00:52:13.470 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2022-12-01 00:52:13.481 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:09a2c7c858' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-12-01 00:52:13.482 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:09a2c7c858' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2022-12-01 00:52:18.502 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2022-12-01 00:52:18.502 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2022-12-01 00:52:26.511 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:52:56.500 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:17.572 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 15: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:18.560 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 15: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:19.549 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 15: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:20.549 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 15: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:26.500 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:56.501 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:56.799 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:57.111 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:53:57.399 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:00.319 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 10: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:00.410 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 10: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:00.498 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 10: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:00.587 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 10: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:26.501 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:54:56.502 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
2022-12-01 00:55:26.501 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 16: Not initialized (ie node unknown), ignoring message.
Is the RFC2217 feature on OpenHAB 3.3 functional? If so, what did I miss?
