I have been experiencing a weird behaviour: While openHab is running, I can’t update the repos with (sudo apt-get update). It starts fetching data, but when it reaches openHab repo, it stops…
If I’m right it tries to load the openHab repo when it stops like that at 0%. Also, it seems that it blocks everything on my RPi. You can’t start a new session through SSH while this happening, nor you can’t connect to openHab through web. Ctrl+C helps, but it takes a few seconds to realize that.
If I leave it like that, it will do nothing, just wait there. I had certificate errors, thought that cause this, but today I have resolved them. I have stopped openHab and that time I was able to to update and upgrade without a problem (it was also really fast…).
Restarted openHab, now I have the same problem. Anyone experienced something like this?
What I have tried to get rid of this:
Solved Debian certificate errors I had
Disabled IPv6 (it became a little faster after disabling, but now it stopped working at all. However I don’t think that this can cause this, because I can upgrade while openHab is stopped).
Yes I know that it is released, but it is not yet seen in the packages, nor I was able to update directly (which you supposed in an article).
I’m using testing repo, because I want to get updates faster than the stable, but I don’t want to mess with daily snapshots…
