Hi there,
I’m a new developer on openHAB.
I’ve failed to implement openHAB on my Synology DS415 play.
Therefore, I’ve tried to install this on my iMac with JAVA environment such as below:
java version "1.8.0_102"
Java™ SE Runtime Environment (build 1.8.0_102-b14)
Java HotSpot™ 64-Bit Server VM (build 25.102-b14, mixed mode)
However, I got the below error message while I run the command, ./start.sh
/Users/phoenix/developer/openHAB/openhab-2-2/runtime/bin/setenv: line 161: die: command not found
/Users/phoenix/developer/openHAB/openhab-2-2/runtime/bin/setenv: line 181: [: : integer expression expected
/Users/phoenix/developer/openHAB/openhab-2-2/runtime/bin/karaf: line 261: [: : integer expression expected
/Users/phoenix/developer/openHAB/openhab-2-2/runtime/bin/karaf: line 306: [: : integer expression expected
/Users/phoenix/developer/openHAB/openhab-2-2/runtime/bin/karaf: line 497: /Library/Java/JavaVirtualMachines/jdk1.8.0_102,jdk/Contents/Home/bin/java: No such file or directory
Have no idea how those issues come.
Please help me to clear where I’m wrong or miss.
