I’m trying to configure my Vacuum 1C STYTJ01ZHM without success.
Openhab auto discovers it as unsupported device - which shows as online but doesn’t work.
and writes this in the log:
2020-05-23 14:45:00.602 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoUnsupportedHandler of thing miio:generic:116A439D tried updating channel network#ssid although the handler was already disposed.
2020-05-23 14:45:00.606 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoUnsupportedHandler of thing miio:generic:116A439D tried updating channel network#bssid although the handler was already disposed.
2020-05-23 14:45:00.610 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoUnsupportedHandler of thing miio:generic:116A439D tried updating channel network#rssi although the handler was already disposed.
2020-05-23 14:45:00.613 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoUnsupportedHandler of thing miio:generic:116A439D tried updating channel network#life although the handler was already disposed.
If I try to add the device manually as an MIIO device with the same token and device ID it also doesn’t work and I start getting in the log the following error intermittently:
2020-05-23 14:36:39.476 [hingStatusInfoChangedEvent] - 'miio:vacuum:2fd4d8ae' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR)
2020-05-23 14:36:54.658 [hingStatusInfoChangedEvent] - 'miio:vacuum:2fd4d8ae' changed from OFFLINE (CONFIGURATION_ERROR) to ONLINE
I double checked that the Token is correct (by installing Mi Home 5.4.49).
Also tried to disable the unsupported device.
Any help would be appreciated.
