I’m unable to access OH via my browser, because OH is not providing a service on my eth0 ipv4 interface (ipv6 looks fine from netstat but I’m not able to test it yet). I’ve read a few similar posts, but none of those methods seem to work (see config changes. OH service restarted every time. It was working a week ago and I think it may have not worked after installing mosquitto.
Configs
[00:19:20] openhabian@openHABianPi:~$ cat /etc/default/openhab2
# openHAB 2 service options
## PORTS
## The ports openHAB will bind its HTTP/HTTPS web server to.
OPENHAB_HTTP_PORT=9080
OPENHAB_HTTPS_PORT=9443
## HTTP(S) LISTEN ADDRESS
## The listen address used by the HTTP(S) server.
## 0.0.0.0 (default) allows a connection from any location
## 127.0.0.1 only allows the local machine to connect
OPENHAB_HTTP_ADDRESS=0.0.0.0
and
[00:19:30] openhabian@openHABianPi:~$ tail /etc/openhab2/services/runtime.cfg
# This setting allows to switch between a "simple" and an "advanced" mode for item management.
# In simple mode (autoLinks=true), links and their according items are automatically created for new Things.
# In advanced mode (autoLinks=false), the user has the full control about which items channels are linked to.
# Existing links will remain untouched. (default is true)
#org.eclipse.smarthome.links:autoLinks=false
org.eclipse.smarthome.network:primaryAddress=192.168.2.1/24
org.eclipse.smarthome.network:broadcastAddress=192.168.2.255
org.eclipse.smarthome.core.net.NetUtil:primaryAddress=192.168.2.0/24
[00:23:44] openhabian@openHABianPi:~$
[07:25:48] openhabian@openHABianPi:~$ tail -n 20 -f /var/log/openhab2/openhab.log
2018-06-19 07:10:34.850 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tradfri:0220:gwb8d7af2b3e31:65555' to inbox.
2018-06-19 07:23:23.817 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-06-19 07:23:35.029 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-06-19 07:23:35.065 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-06-19 07:23:35.085 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-06-19 07:23:35.112 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-06-19 07:23:52.293 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-06-19 07:23:54.703 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.1:9080
2018-06-19 07:23:54.709 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.1:9443
2018-06-19 07:23:58.568 [WARN ] [iscovery.TradfriDiscoveryParticipant] - Discovered Tradfri gateway doesn't have an IP address: [ServiceInfoImpl@26265326 name: 'gw-b8d7af2b3e31._coap._udp.local.' address: '(null):0' status: 'DNS: JmDNS-IP-1 [/192.168.2.1] state: probing 1 task: null', has NO data, empty]
2018-06-19 07:24:04.111 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-06-19 07:24:06.384 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2018-06-19 07:24:07.453 [WARN ] [radfri.handler.TradfriGatewayHandler] - Gateway with old firmware - please consider upgrading to the latest version.
2018-06-19 07:24:09.720 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-06-19 07:24:09.897 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-06-19 07:24:10.059 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-06-19 07:24:13.569 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tradfri:0220:gwb8d7af2b3e31:65554' to inbox.
2018-06-19 07:24:13.578 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tradfri:0220:gwb8d7af2b3e31:65553' to inbox.
2018-06-19 07:24:13.613 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tradfri:0820:gwb8d7af2b3e31:65552' to inbox.
2018-06-19 07:24:13.632 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tradfri:0220:gwb8d7af2b3e31:65555' to inbox.
Going back further to when I was having problems…
There are a lot of these entries about 6 hours ago
2018-06-17 01:14:02.568 [WARN ] [e.californium.scandium.DTLSConnector] - Could not send datagram
java.io.IOException: Network is unreachable (sendto failed)
at java.net.PlainDatagramSocketImpl.send(Native Method) ~[?:?]
at java.net.DatagramSocket.send(DatagramSocket.java:693) [?:?]
at org.eclipse.californium.scandium.DTLSConnector.sendFlight(DTLSConnector.java:1285) [200:org.eclipse.californium.scandium:1.0.6]
at org.eclipse.californium.scandium.DTLSConnector.handleTimeout(DTLSConnector.java:1312) [200:org.eclipse.californium.scandium:1.0.6]
at org.eclipse.californium.scandium.DTLSConnector.access$500(DTLSConnector.java:105) [200:org.eclipse.californium.scandium:1.0.6]
at org.eclipse.californium.scandium.DTLSConnector$RetransmitTask.run(DTLSConnector.java:1424) [200:org.eclipse.californium.scandium:1.0.6]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:?]
at java.util.TimerThread.run(Timer.java:505) [?:?]
2018-06-17 01:14:06.572 [WARN ] [e.californium.scandium.DTLSConnector] - Could not send datagram
[07:24:00] openhabian@openHABianPi:~$ sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-06-19 07:23:42 BST; 26s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 9908 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 10074 (java)
CGroup: /system.slice/openhab2.service
├─10074 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenha
├─10342 ping -w 5 -c 1 192.168.1.78
└─10364 ping -w 5 -c 1 192.168.1.84
Jun 19 07:23:42 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
lines 1-13/13 (END)
