Hi.
I have the following errors when trying to install. I install by copying from the kar file to /usr/share/openhab/addons/ I have version 2.5.12. Where is the problem?
Files:
org.openhab.binding.modbus-2.5.12.jar
org.openhab.io.transport.modbus-2.5.12.jar
2022-09-30 18:52:51.245 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.io.transport.modbus-2.5.12.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.io.transport.modbus [304]
Unresolved requirement: Import-Package: org.apache.commons.pool2; version="[2.8.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2022-09-30 18:52:51.272 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.modbus-2.5.12.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.modbus [305]
Unresolved requirement: Import-Package: org.openhab.io.transport.modbus
-> Export-Package: org.openhab.io.transport.modbus; bundle-symbolic-name="org.openhab.io.transport.modbus"; bundle-version="2.5.12"; version="2.5.12"; uses:="org.eclipse.smarthome.core.library.types,org.eclipse.smarthome.core.types,org.openhab.io.transport.modbus.endpoint"
Unresolved requirement: Import-Package: org.openhab.io.transport.modbus.endpoint
-> Export-Package: org.openhab.io.transport.modbus.endpoint; bundle-symbolic-name="org.openhab.io.transport.modbus"; bundle-version="2.5.12"; version="2.5.12"
