I have docker container (downloaded from “https://hub.docker.com/r/openhab/openhab/”) running on my vm. I want to use persistence service and also configured it in addons.cfg and services.cfg.But I am getting these logs on startup
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
08:23:27.971 [INFO ] [.openhab.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build 201501141133).
Please tell me from where do I get the latest compat1x layers to support OH1 persistence service
But over all it almost looks like your userdata folder got corrupted somewhere. If you delete that folder and restart the container (I’m assuming you have userdata mounted as a volume) does the error go away?
One thing to realize with a Docker instance is that every time you upgrade the image, you will need to wipe out userdata/cache and userdata/tmp to force the bindings to reinstall (or upgrade them individually through the Karaf console). Otherwise your bindings do not upgrade.
2016-11-22 12:18:53.779 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-11-22 12:18:54.445 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-11-22 12:18:54.626 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-11-22 12:18:54.803 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-22 12:18:55.120 [ERROR] [.eclipse.smarthome.model.persistence] - [org.eclipse.smarthome.core.persistence.manager(82)] The addPersistenceService method has thrown an exception
java.lang.NullPointerException
at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.removeTimers(PersistenceManager.java:455)
at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.stopEventHandling(PersistenceManager.java:201)
at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.addPersistenceService(PersistenceManager.java:143)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BindMethod.invoke(BindMethod.java:41)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1660)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1636)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:370)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:319)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:295)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[34:org.apache.felix.scr:2.0.2]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:998)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.openhab.core.persistence.internal.PersistenceServiceFactory.registerDelegateService(PersistenceServiceFactory.java:72)
at org.openhab.core.persistence.internal.PersistenceServiceFactory.addPersistenceService(PersistenceServiceFactory.java:52)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[34:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[34:org.apache.felix.scr:2.0.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
Please see the logs and tell me what I have to do resolved this error.
A1) I followed text approch.
A2) Mongodb.
A3) Yes default persistence is set.
A4) Yes I deleted the userdata and cache folder and then I restarted the OH and same issue appears.
Also getting this error in logs :
Failed installing ‘openhab-persistence-mongodb’: No matching features for openhab-persistence-mongodb/0.0.0
“mongodb” is not listed as one of the included addons. You cannot install it using addons.cfg. You need to follow the instructions here. The tl;dr version is you need to install the 1.x compatibility layer, put the jar file in the addons folder (you will have to map that into the container through a volume) and copy over an openhab.cfg with the mongodb configuration parameters.
I don’t think 1.x bindings installed via the 1.x compatibility layer show up when you do a feature:list.
EVERYTHING about installing and configuring the binding once you have the compat layer is identical to how it worked in OH 1.x.
You must put the jar file into addons.
You must have an openhab.cfg in conf/services with everything commented out except for the section that applies to you compat layer installed bindings.
For Docker, the addons folder needs to be mapped to /openhab/addons in the container.
There is a possibility that the MongoDB addon is not compatible with OH 2 for some reason. There are a small number of already identified addons that are not, usually because of unavailability of some library that used to come with OH 1.x but no longer comes with OH 2. But if that were the case the error would have been different I think.
I have had some bindings not work from within Docker because of the security around Docker networking and the limited environment inside the container.
Exec, Network, and http actions are three such addons. If this binding requires something be installed on the system or some shirt off network access it might not work.
I have configured container as well as all config files from scratch. I see persistence bundle is listed as active. But getting following error:
04:56:40.921 [ERROR] [.eclipse.smarthome.model.persistence] - [org.eclipse.smarthome.core.persistence.manager(87)] The addPersistenceService method has thrown an exception
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:370)[36:org.apache.felix.scr:2.0.2]
at org.openhab.core.persistence.internal.PersistenceServiceFactory.activate(PersistenceServiceFactory.java:38)
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:302)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:113)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:866)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:833)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:724)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[36:org.apache.felix.scr:2.0.2]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[36:org.apache.felix.scr:2.0.2]
docker container has /etc folder missing in runtime folder and services.cfg file is at runtime level.
In runtime without docker, /runtime foder contains /etc folder and /etc folder contains two files - services.cfg and quartz.properties.
so in docker container, I created /etc folder and created both files - services.cfg and quartz.properties and now my persistence binding is running properly.
