Unable to login on my.openhab.org website (Android App is OK)
See title.
I reset my password, but still getting a message that my password or login is wrong.
Herman van Horssen
Strange … already the second user with the same problem (no login after password reset):
I tried to login one minute ago (although without password reset) and it works fine …
I did the password reset to try to solve the login issue.
I am sure I used the correct password also before the reset.
Do you have any special characters in your password? Sometimes logins don’t like that …
I use just characters and numbers
Hmmm …
Maybe you are on an older java version?
my.openhab only works with java version greater than 101:
pi@raspberrypi2 ~ $ java -version
java version "1.8.0_111"
Java(TM) SE Runtime Environment (build 1.8.0_111-b14)
Java HotSpot(TM) Client VM (build 25.111-b14, mixed mode)
Disregard my last post, that should have nothing to do with the login …
