This is what happened when I ran sudo systemctl status openhab2.service
[17:36:41] openhabian@openHABianDevice:~$ sudo systemctl status openhab2.service
[sudo] password for openhabian:
Warning: The unit file, source configuration file or drop-ins of openhab2.service changed on
● openhab2.service - openHAB2 instance, reachable at http://openHABianDevice:8080
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab2.service.d
└─override.conf
Active: active (running) since Fri 2020-10-30 11:57:39 CET; 6 days ago
Docs: Introduction | openHAB
https://community.openhab.org
Process: 708 ExecStartPre=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name “.rules" -exec
Process: 726 ExecStartPost=/bin/sleep 120 (code=exited, status=0/SUCCESS)
Process: 1801 ExecStartPost=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name ".x” -exec /u
Main PID: 724 (java)
Tasks: 94 (limit: 4915)
CGroup: /system.slice/openhab2.service
└─724 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab
Oct 26 14:30:48 openHABianDevice systemd[1]: Starting openHAB2 instance, reachable at http://
Oct 30 11:57:39 openHABianDevice systemd[1]: Started openHAB2 instance, reachable at http://o
lines 1-18/18 (END)…skipping…
Warning: The unit file, source configuration file or drop-ins of openhab2.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
└─override.conf
Process: 708 ExecStartPre=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name “.rules" -exec /usr/bin/rename.ul .rules .x {} ; (code=exited, status=0/SUCCESS)
Process: 1801 ExecStartPost=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name ".x” -exec /usr/bin/rename.ul .x .rules {} ; (code=exited, status=0/SUCCESS)
└─724 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.l
Oct 26 14:30:48 openHABianDevice systemd[1]: Starting openHAB2 instance, reachable at http://openHABianDevice:8080…
Oct 30 11:57:39 openHABianDevice systemd[1]: Started openHAB2 instance, reachable at http://openHABianDevice:8080.
lines 1-18/18 (END)
This is what came up when I ran SSH - cat /boot/first-boot.log
[17:39:42] openhabian@openHABianDevice:~$ cat /boot/first-boot.log
2020-08-20_10:48:02_UTC [openHABian] Starting the openHABian initial setup.
2020-08-20_10:48:02_UTC [openHABian] Storing configuration… OK
2020-08-20_10:48:02_UTC [openHABian] Starting webserver with installation log… OK
2020-08-20_10:48:07_UTC [openHABian] Changing default username and password… OK
2020-08-20_10:48:08_UTC [openHABian] Setting up Ethernet connection… OK
2020-08-20_10:48:08_UTC [openHABian] Ensuring network connectivity… OK
2020-08-20_10:48:08_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2020-10-26_09:55:00_UTC [openHABian] Updating repositories and upgrading installed packages… OK (rebooting)
2020-10-26_09:57:33_GMT [openHABian] Starting the openHABian initial setup.
2020-10-26_09:57:33_GMT [openHABian] Storing configuration… OK
2020-10-26_09:57:33_GMT [openHABian] Starting webserver with installation log… OK
2020-10-26_09:57:38_GMT [openHABian] Changing default username and password… SKIPPED
2020-10-26_09:57:38_GMT [openHABian] Setting up Ethernet connection… OK
2020-10-26_09:57:38_GMT [openHABian] Ensuring network connectivity… OK
2020-10-26_09:57:38_GMT [openHABian] Waiting for dpkg/apt to get ready… OK
2020-10-26_09:57:44_GMT [openHABian] Updating repositories and upgrading installed packages… OK
2020-10-26_09:57:47_GMT [openHABian] Installing git package… OK
2020-10-26_09:58:14_GMT [openHABian] Updating myself from GitHub - openhab/openhabian: openHABian - empowering the smart home, for Raspberry Pi and Debian systems, stable branch… OK
2020-10-26_09:58:18_GMT [openHABian] Starting execution of ‘openhabian-config unattended’… OK
2020-10-26_09:58:18_GMT [openHABian] Checking for root privileges… OK
2020-10-26_09:58:18_GMT [openHABian] Updating Linux package information… OK
2020-10-26_09:58:23_GMT [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2020-10-26_09:58:23_GMT [openHABian] Setting timezone based on openhabian.conf… OK (Europe/Berlin)
2020-10-26_10:58:23_CET [openHABian] Enabling time synchronization using NTP… OK
2020-10-26_10:58:24_CET [openHABian] Setting locale based on openhabian.conf… OK (reboot required)
2020-10-26_10:58:59_CET [openHABian] Setting hostname of the base system based on openhabian.conf… OK
2020-10-26_10:58:59_CET [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2020-10-26_10:58:59_CET [openHABian] Enabling Audio output… OK
2020-10-26_10:59:00_CET [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2020-10-26_10:59:31_CET [openHABian] Installing additional needed packages… OK
2020-10-26_11:00:09_CET [openHABian] Installing additional bluetooth packages… OK
2020-10-26_11:00:16_CET [openHABian] Adding slightly tuned bash configuration files to system… OK
2020-10-26_11:00:16_CET [openHABian] Adding slightly tuned vim configuration file to system… OK
2020-10-26_11:00:16_CET [openHABian] Downloading FireMotD… OK
2020-10-26_11:00:19_CET [openHABian] Installing FireMotD… OK
2020-10-26_11:00:19_CET [openHABian] Generating FireMotD theme… OK
2020-10-26_11:00:30_CET [openHABian] Setting up FireMotD apt updates count service… OK
2020-10-26_11:00:39_CET [openHABian] Installing cached version of Java to ensure that some form of Java is installed!
2020-10-26_11:00:39_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)… OK
2020-10-26_11:00:39_CET [openHABian] Installing Java Zulu 8 32-Bit OpenJDK… OK
2020-10-26_11:00:39_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength… OK
2020-10-26_11:00:42_CET [openHABian] Beginning install of latest openHAB release (stable)… OK
2020-10-26_11:00:42_CET [openHABian] Adding required keys to apt… OK
2020-10-26_11:00:43_CET [openHABian] Installing selected openHAB version… OK
2020-10-26_11:01:27_CET [openHABian] Setting up openHAB service… OK
2020-10-26_11:01:28_CET [openHABian] Optimizing openHAB to run on low memory single board computers… OK
2020-10-26_11:01:28_CET [openHABian] Setting openHAB HTTP/HTTPS ports… OK
2020-10-26_11:01:28_CET [openHABian] Creating dependencies to jointly start services that depend on each other… OK
2020-10-26_11:01:28_CET [openHABian] Adding delay on loading openHAB rules… OK
2020-10-26_11:03:28_CET [openHABian] Adding an openHAB dashboard tile for ‘openhabiandocs’… OK
2020-10-26_11:03:28_CET [openHABian] Adding openHAB syntax to vim editor… OK
2020-10-26_11:03:30_CET [openHABian] Adding openHAB syntax to nano editor… OK
2020-10-26_11:03:31_CET [openHABian] Adding openHAB scheme to multitail… OK
2020-10-26_11:03:31_CET [openHABian] Preparing openHAB folder mounts under ‘/srv/openhab2-*’… OK
2020-10-26_11:03:36_CET [openHABian] Applying miscellaneous system settings… OK
2020-10-26_11:03:36_CET [openHABian] Installing Samba… OK
2020-10-26_11:04:10_CET [openHABian] Setting up Samba network shares… OK
2020-10-26_11:04:11_CET [openHABian] Setting up Samba service… OK
2020-10-26_11:04:13_CET [openHABian] Applying file permissions recommendations… OK
2020-10-26_11:04:14_CET [openHABian] Installing Frontail prerequsites (NodeJS)… OK
2020-10-26_11:04:38_CET [openHABian] Installing openHAB Log Viewer (frontail)… OK
2020-10-26_11:04:58_CET [openHABian] Configuring openHAB Log Viewer (frontail)… OK
2020-10-26_11:04:58_CET [openHABian] Setting up openHAB Log Viewer (frontail) service… OK
2020-10-26_11:04:59_CET [openHABian] Adding an openHAB dashboard tile for ‘frontail’… OK
2020-10-26_11:04:59_CET [openHABian] We’ve detected you’re using the 8GB model of the RPi4. It is known to not work with ZRAM.2020-10-26_11:04:59_CET [openHABian] Skipping ZRAM install as requested.2020-10-26_11:04:59_CET [openHABian] Beginning Mail Transfer Agent setup… CANCELED (no configuration provided)
2020-10-26_11:04:59_CET [openHABian] Setting up automated SD mirroring and backup… CANCELED (no configuration provided)
2020-10-26_11:04:59_CET [openHABian] Cleaning up… OK
2020-10-26_11:05:12_CET [openHABian] Execution of ‘openhabian-config unattended’ completed.
2020-10-26_11:05:12_CET [openHABian] Waiting for openHAB to become ready on openHABianDevice… OK
2020-10-26_11:05:12_CET [openHABian] First time setup successfully finished. Rebooting your system!
2020-10-26_11:05:12_CET [openHABian] After rebooting the openHAB dashboard will be available at: http://openHABianDevice:8080
2020-10-26_11:05:12_CET [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
This is what happened when I tried to uninstall ZRAM
[17:41:58] openhabian@openHABianDevice:~$ sudo openhabian-config
2020-11-05_17:44:26_CET [openHABian] Checking for root privileges… OK
2020-11-05_17:44:26_CET [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2020-11-05_17:44:26_CET [openHABian] openHABian configuration tool version: [stable]v1.6-880(769ea17)
2020-11-05_17:44:26_CET [openHABian] Checking for changes in origin branch stable… OK
2020-11-05_17:44:39_CET [openHABian] Switching to branch stable… OK
2020-11-05_17:44:49_CET [openHABian] Updating Linux package information… OK
2020-11-05_17:44:49_CET [openHABian] Removing ZRAM service… FAILED (disable service)
This is what happened when I ran sudo systemctl status openhab2.service after rebooting my raspberry pi
[17:51:56] openhabian@openHABianDevice:~$ sudo systemctl status openhab2.service
└─override.conf
Active: activating (start-post) since Thu 2020-11-05 17:51:02 CET; 1min 16s ago
Process: 676 ExecStartPre=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name “*.rules” -exec /usr/bin/rename.ul .rules .x {} ; (code=exited, status=0/SUCCESS)
Main PID: 683 (java); Control PID: 684 (sleep)
Tasks: 97 (limit: 4915)
├─683 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.l
└─684 /bin/sleep 120
Nov 05 17:51:02 openHABianDevice systemd[1]: Starting openHAB2 instance, reachable at http://openHABianDevice:8080…
lines 1-16/16 (END)
This is what happened when I ran /sbin/ip route get 8.8.8.8
[17:55:52] openhabian@openHABianDevice:~$ /sbin/ip route get 8.8.8.8
8.8.8.8 via 192.168.0.1 dev eth0 src 192.168.0.51 uid 1000
Cache
This is what happened when I ran sudo netstat -tulpe --numeric-ports |grep java
[17:59:26] openhabian@openHABianDevice:~$ sudo netstat -tulpe --numeric-ports |grep java
tcp6 0 0 localhost:36665 [::]:* LISTEN openhab 15984 683/java
tcp6 0 0 [::]:8443 [::]:* LISTEN openhab 16317 683/java
tcp6 0 0 localhost:8101 [::]:* LISTEN openhab 19928 683/java
tcp6 0 0 [::]:5007 [::]:* LISTEN openhab 16324 683/java
tcp6 0 0 [::]:8080 [::]:* LISTEN openhab 16320 683/java
udp6 0 0 [::]:5353 [::]:* openhab 18890 683/java
This is what happened when I reinstalled from scratch on a new SD Card & edited the openhabian.conf file so clonebranch=master, debugmode=maximum, ipv6=disable and zraminstall=disable and ran /boot/first-boot.log
[19:47:05] openhabian@openHABianDevice:~$ /boot/first-boot.log
/boot/first-boot.log: line 3: 2020-08-20_10:48:00_UTC: command not found
/boot/first-boot.log: line 4: 2020-08-20_10:48:00_UTC: command not found
/boot/first-boot.log: line 5: 2020-08-20_10:48:00_UTC: command not found
/boot/first-boot.log: line 6: ++: command not found
/boot/first-boot.log: line 7: ++: command not found
/boot/first-boot.log: line 8: +: command not found
/boot/first-boot.log: line 9: 2020-08-20_10:48:00_UTC: command not found
/boot/first-boot.log: line 10: +: command not found
/boot/first-boot.log: line 11: +: command not found
/boot/first-boot.log: line 12: +: command not found
/boot/first-boot.log: line 13: ++: command not found
/boot/first-boot.log: line 14: ++: command not found
/boot/first-boot.log: line 15: +: command not found
/boot/first-boot.log: line 16: +: command not found
/boot/first-boot.log: line 17: +: command not found
/boot/first-boot.log: line 18: OK: command not found
/boot/first-boot.log: line 19: +: command not found
/boot/first-boot.log: line 20: +: command not found
/boot/first-boot.log: line 21: +: command not found
/boot/first-boot.log: line 22: +: command not found
/boot/first-boot.log: line 23: +: command not found
/boot/first-boot.log: line 24: +: command not found
/boot/first-boot.log: line 25: +: command not found
/boot/first-boot.log: line 26: +: command not found
/boot/first-boot.log: line 27: +: command not found
/boot/first-boot.log: line 28: +: command not found
/boot/first-boot.log: line 29: +: command not found
/boot/first-boot.log: line 30: +: command not found
/boot/first-boot.log: line 31: +: command not found
/boot/first-boot.log: line 32: +: command not found
/boot/first-boot.log: line 33: +: command not found
/boot/first-boot.log: line 34: +: command not found
/boot/first-boot.log: line 35: +: command not found
/boot/first-boot.log: line 36: +: command not found
/boot/first-boot.log: line 37: +: command not found
/boot/first-boot.log: line 38: +: command not found
/boot/first-boot.log: line 39: +: command not found
/boot/first-boot.log: line 40: +: command not found
/boot/first-boot.log: line 41: +: command not found
/boot/first-boot.log: line 42: +: command not found
/boot/first-boot.log: line 43: +: command not found
/boot/first-boot.log: line 44: +: command not found
/boot/first-boot.log: line 45: +: command not found
/boot/first-boot.log: line 46: +: command not found
/boot/first-boot.log: line 47: +: command not found
/boot/first-boot.log: line 48: +: command not found
/boot/first-boot.log: line 49: +: command not found
/boot/first-boot.log: line 50: +: command not found
/boot/first-boot.log: line 51: +: command not found
/boot/first-boot.log: line 52: +: command not found
/boot/first-boot.log: line 53: +: command not found
/boot/first-boot.log: line 54: +: command not found
/boot/first-boot.log: line 55: +: command not found
/boot/first-boot.log: line 56: +: command not found
/boot/first-boot.log: line 57: +: command not found
/boot/first-boot.log: line 58: +: command not found
/boot/first-boot.log: line 59: +: command not found
/boot/first-boot.log: line 60: +: command not found
/boot/first-boot.log: line 61: +: command not found
/boot/first-boot.log: line 62: +: command not found
/boot/first-boot.log: line 63: +: command not found
/boot/first-boot.log: line 64: ++: command not found
/boot/first-boot.log: line 65: ++: command not found
/boot/first-boot.log: line 66: +: command not found
/boot/first-boot.log: line 67: 2020-08-20_10:48:05_UTC: command not found
/boot/first-boot.log: line 68: +: command not found
/boot/first-boot.log: line 69: +: command not found
/boot/first-boot.log: line 70: +: command not found
/boot/first-boot.log: line 71: +: command not found
/boot/first-boot.log: line 72: +: command not found
/boot/first-boot.log: line 73: +: command not found
/boot/first-boot.log: line 74: +: command not found
/boot/first-boot.log: line 75: +: command not found
/boot/first-boot.log: line 76: OK: command not found
/boot/first-boot.log: line 77: +: command not found
/boot/first-boot.log: line 78: +: command not found
/boot/first-boot.log: line 79: ++: command not found
/boot/first-boot.log: line 80: ++: command not found
/boot/first-boot.log: line 81: +: command not found
/boot/first-boot.log: line 82: 2020-08-20_10:48:06_UTC: command not found
/boot/first-boot.log: line 83: +: command not found
/boot/first-boot.log: line 84: OK: command not found
/boot/first-boot.log: line 85: ++: command not found
/boot/first-boot.log: line 86: ++: command not found
/boot/first-boot.log: line 87: +: command not found
/boot/first-boot.log: line 88: 2020-08-20_10:48:06_UTC: command not found
/boot/first-boot.log: line 89: +: command not found
/boot/first-boot.log: line 90: +: command not found
/boot/first-boot.log: line 91: +: command not found
/boot/first-boot.log: line 92: +: command not found
/boot/first-boot.log: line 93: +: command not found
/boot/first-boot.log: line 94: +: command not found
/boot/first-boot.log: line 95: +: command not found
/boot/first-boot.log: line 96: +: command not found
/boot/first-boot.log: line 97: +: command not found
/boot/first-boot.log: line 98: ++: command not found
/boot/first-boot.log: line 99: +++: command not found
/boot/first-boot.log: line 100: +: command not found
/boot/first-boot.log: line 101: +: command not found
/boot/first-boot.log: line 102: +: command not found
/boot/first-boot.log: line 103: +: command not found
/boot/first-boot.log: line 104: +: command not found
/boot/first-boot.log: line 105: OK: command not found
/boot/first-boot.log: line 106: ++: command not found
/boot/first-boot.log: line 107: ++: command not found
/boot/first-boot.log: line 108: +: command not found
/boot/first-boot.log: line 109: 2020-08-20_10:48:06_UTC: command not found
/boot/first-boot.log: line 110: +: command not found
/boot/first-boot.log: line 111: +: command not found
/boot/first-boot.log: line 112: +: command not found
/boot/first-boot.log: line 113: +: command not found
/boot/first-boot.log: line 114: +: command not found
/boot/first-boot.log: line 115: +: command not found
/boot/first-boot.log: line 116: +: command not found
/boot/first-boot.log: line 117: +: command not found
/boot/first-boot.log: line 118: +++: command not found
/boot/first-boot.log: line 119: ++: command not found
/boot/first-boot.log: line 120: +: command not found
/boot/first-boot.log: line 121: +: command not found
/boot/first-boot.log: line 122: +: command not found
/boot/first-boot.log: line 123: OK: command not found
/boot/first-boot.log: line 124: ++: command not found
/boot/first-boot.log: line 125: ++: command not found
/boot/first-boot.log: line 126: +: command not found
/boot/first-boot.log: line 127: ++: command not found
/boot/first-boot.log: line 128: ++: command not found
/boot/first-boot.log: line 129: +: command not found
/boot/first-boot.log: line 130: 2020-11-05_17:56:41_UTC: command not found
/boot/first-boot.log: line 131: +++: command not found
/boot/first-boot.log: line 132: ++: command not found
/boot/first-boot.log: line 133: +: command not found
/boot/first-boot.log: line 134: ++: command not found
/boot/first-boot.log: line 135: ++: command not found
/boot/first-boot.log: line 136: +: command not found
/boot/first-boot.log: line 137: +: command not found
/boot/first-boot.log: line 138: OK: command not found
/boot/first-boot.log: line 139: ++: command not found
/boot/first-boot.log: line 140: +: command not found
/boot/first-boot.log: line 141: +: command not found
/boot/first-boot.log: line 142: ++: command not found
/boot/first-boot.log: line 143: +: command not found
/boot/first-boot.log: line 144: ++: command not found
/boot/first-boot.log: line 145: ++: command not found
/boot/first-boot.log: line 146: +: command not found
/boot/first-boot.log: line 147: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 148: +: command not found
/boot/first-boot.log: line 149: FAILED: command not found
/boot/first-boot.log: line 150: ++: command not found
/boot/first-boot.log: line 151: ++: command not found
/boot/first-boot.log: line 152: +: command not found
/boot/first-boot.log: line 153: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 154: +: command not found
/boot/first-boot.log: line 155: +: command not found
/boot/first-boot.log: line 156: FAILED: command not found
/boot/first-boot.log: line 157: ++: command not found
/boot/first-boot.log: line 158: ++: command not found
/boot/first-boot.log: line 159: +: command not found
/boot/first-boot.log: line 160: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 161: ++: command not found
/boot/first-boot.log: line 162: ++: command not found
/boot/first-boot.log: line 163: +: command not found
/boot/first-boot.log: line 164: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 165: +: command not found
/boot/first-boot.log: line 166: +: command not found
/boot/first-boot.log: line 167: +: command not found
/boot/first-boot.log: line 168: ++: command not found
/boot/first-boot.log: line 169: ++: command not found
/boot/first-boot.log: line 170: +: command not found
/boot/first-boot.log: line 171: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 172: +: command not found
/boot/first-boot.log: line 173: 2020-11-05_17:56:42_UTC: command not found
/boot/first-boot.log: line 174: +: command not found
/boot/first-boot.log: line 175: +: command not found
/boot/first-boot.log: line 176: +: command not found
/boot/first-boot.log: line 177: +: command not found
/boot/first-boot.log: line 178: +: command not found
/boot/first-boot.log: line 179: +: command not found
/boot/first-boot.log: line 180: +: command not found
/boot/first-boot.log: line 181: +: command not found
/boot/first-boot.log: line 182: +: command not found
/boot/first-boot.log: line 183: +: command not found
/boot/first-boot.log: line 184: +: command not found
/boot/first-boot.log: line 185: ++: command not found
/boot/first-boot.log: line 186: ++: command not found
/boot/first-boot.log: line 187: ++: command not found
/boot/first-boot.log: line 188: ++: command not found
/boot/first-boot.log: line 189: ++: command not found
/boot/first-boot.log: line 190: ++: command not found
/boot/first-boot.log: line 191: ++: command not found
/boot/first-boot.log: line 192: ++: command not found
/boot/first-boot.log: line 193: ++: command not found
/boot/first-boot.log: line 194: ++: command not found
/boot/first-boot.log: line 195: ++: command not found
/boot/first-boot.log: line 196: +: command not found
/boot/first-boot.log: line 197: +: command not found
/boot/first-boot.log: line 198: +: command not found
/boot/first-boot.log: line 199: +: command not found
/boot/first-boot.log: line 200: +: command not found
/boot/first-boot.log: line 201: +: command not found
/boot/first-boot.log: line 202: +: command not found
/boot/first-boot.log: line 203: +: command not found
/boot/first-boot.log: line 204: +: command not found
/boot/first-boot.log: line 205: +: command not found
/boot/first-boot.log: line 206: +: command not found
/boot/first-boot.log: line 207: +: command not found
/boot/first-boot.log: line 208: +: command not found
/boot/first-boot.log: line 209: +: command not found
/boot/first-boot.log: line 210: +: command not found
/boot/first-boot.log: line 211: +: command not found
/boot/first-boot.log: line 212: +: command not found
/boot/first-boot.log: line 213: +: command not found
/boot/first-boot.log: line 214: +: command not found
/boot/first-boot.log: line 215: +: command not found
/boot/first-boot.log: line 216: +: command not found
/boot/first-boot.log: line 217: +: command not found
/boot/first-boot.log: line 218: +: command not found
/boot/first-boot.log: line 219: +: command not found
/boot/first-boot.log: line 220: ++: command not found
/boot/first-boot.log: line 221: +: command not found
/boot/first-boot.log: line 222: +: command not found
/boot/first-boot.log: line 223: +: command not found
/boot/first-boot.log: line 224: +: command not found
/boot/first-boot.log: line 225: +: command not found
/boot/first-boot.log: line 226: +: command not found
/boot/first-boot.log: line 227: ++: command not found
/boot/first-boot.log: line 228: ++: command not found
/boot/first-boot.log: line 229: +: command not found
/boot/first-boot.log: line 230: 2020-11-05_17:56:48_UTC: command not found
/boot/first-boot.log: line 231: +: command not found
/boot/first-boot.log: line 232: +: command not found
/boot/first-boot.log: line 233: cp:: command not found
/boot/first-boot.log: line 234: +: command not found
/boot/first-boot.log: line 235: +: command not found
/boot/first-boot.log: line 236: +: command not found
/boot/first-boot.log: line 238: $‘\E[90’: command not found
/boot/first-boot.log: line 238: 01m$: command not found
/boot/first-boot.log: line 238: 49: command not found
/boot/first-boot.log: line 238: 00m: command not found
/boot/first-boot.log: line 239: +: command not found
/boot/first-boot.log: line 240: net.ipv6.conf.all.disable_ipv6: command not found
/boot/first-boot.log: line 241: net.ipv6.conf.default.disable_ipv6: command not found
/boot/first-boot.log: line 242: net.ipv6.conf.lo.disable_ipv6: command not found
/boot/first-boot.log: line 243: +: command not found
/boot/first-boot.log: line 244: +: command not found
/boot/first-boot.log: line 245: OK: command not found
/boot/first-boot.log: line 246: +: command not found
/boot/first-boot.log: line 247: +: command not found
/boot/first-boot.log: line 248: +: command not found
/boot/first-boot.log: line 249: +: command not found
/boot/first-boot.log: line 250: ++: command not found
/boot/first-boot.log: line 251: ++: command not found
/boot/first-boot.log: line 252: +: command not found
/boot/first-boot.log: line 253: 2020-11-05_17:56:48_UTC: command not found
/boot/first-boot.log: line 254: +: command not found
/boot/first-boot.log: line 255: +: command not found
/boot/first-boot.log: line 256: +: command not found
/boot/first-boot.log: line 257: +: command not found
/boot/first-boot.log: line 258: +: command not found
/boot/first-boot.log: line 259: OK: command not found
/boot/first-boot.log: line 260: +: command not found
/boot/first-boot.log: line 261: +: command not found
/boot/first-boot.log: line 262: +: command not found
/boot/first-boot.log: line 263: +: command not found
/boot/first-boot.log: line 264: ++: command not found
/boot/first-boot.log: line 265: ++: command not found
/boot/first-boot.log: line 266: +: command not found
/boot/first-boot.log: line 267: 2020-11-05_17:57:00_UTC: command not found
/boot/first-boot.log: line 268: ++: command not found
/boot/first-boot.log: line 269: ++: command not found
/boot/first-boot.log: line 270: ++: command not found
/boot/first-boot.log: line 271: ++: command not found
/boot/first-boot.log: line 272: ++: command not found
/boot/first-boot.log: line 273: ++: command not found
/boot/first-boot.log: line 274: ++: command not found
/boot/first-boot.log: line 275: ++: command not found
/boot/first-boot.log: line 276: ++: command not found
/boot/first-boot.log: line 277: ++: command not found
/boot/first-boot.log: line 278: ++: command not found
/boot/first-boot.log: line 279: ++: command not found
/boot/first-boot.log: line 280: ++: command not found
/boot/first-boot.log: line 281: ++: command not found
/boot/first-boot.log: line 282: ++: command not found
/boot/first-boot.log: line 283: +: command not found
/boot/first-boot.log: line 284: OK: command not found
/boot/first-boot.log: line 285: +: command not found
/boot/first-boot.log: line 286: +: command not found
/boot/first-boot.log: line 287: +: command not found
/boot/first-boot.log: line 288: +: command not found
/boot/first-boot.log: line 289: +: command not found
/boot/first-boot.log: line 290: +: command not found
/boot/first-boot.log: line 291: +: command not found
/boot/first-boot.log: line 292: +: command not found
/boot/first-boot.log: line 293: +: command not found
/boot/first-boot.log: line 294: +: command not found
/boot/first-boot.log: line 295: +: command not found
/boot/first-boot.log: line 296: +: command not found
/boot/first-boot.log: line 297: +: command not found
/boot/first-boot.log: line 298: +: command not found
/boot/first-boot.log: line 299: +: command not found
/boot/first-boot.log: line 300: +: command not found
/boot/first-boot.log: line 301: +: command not found
/boot/first-boot.log: line 302: +: command not found
/boot/first-boot.log: line 303: +: command not found
/boot/first-boot.log: line 304: +: command not found
/boot/first-boot.log: line 305: +: command not found
/boot/first-boot.log: line 306: +: command not found
/boot/first-boot.log: line 307: +: command not found
/boot/first-boot.log: line 308: +: command not found
/boot/first-boot.log: line 309: +: command not found
/boot/first-boot.log: line 310: +: command not found
/boot/first-boot.log: line 311: +: command not found
/boot/first-boot.log: line 312: +: command not found
/boot/first-boot.log: line 313: +: command not found
/boot/first-boot.log: line 314: +: command not found
/boot/first-boot.log: line 315: +: command not found
/boot/first-boot.log: line 316: +: command not found
/boot/first-boot.log: line 317: +: command not found
/boot/first-boot.log: line 318: +: command not found
/boot/first-boot.log: line 319: +: command not found
/boot/first-boot.log: line 320: +: command not found
/boot/first-boot.log: line 321: +: command not found
/boot/first-boot.log: line 322: +: command not found
/boot/first-boot.log: line 323: +: command not found
/boot/first-boot.log: line 324: +: command not found
/boot/first-boot.log: line 325: +: command not found
/boot/first-boot.log: line 326: +: command not found
/boot/first-boot.log: line 327: +: command not found
/boot/first-boot.log: line 328: +: command not found
/boot/first-boot.log: line 329: +: command not found
/boot/first-boot.log: line 330: +: command not found
/boot/first-boot.log: line 331: +: command not found
/boot/first-boot.log: line 332: +: command not found
/boot/first-boot.log: line 333: ++: command not found
/boot/first-boot.log: line 334: +: command not found
/boot/first-boot.log: line 335: +: command not found
/boot/first-boot.log: line 336: +: command not found
/boot/first-boot.log: line 337: +: command not found
/boot/first-boot.log: line 338: ++: command not found
/boot/first-boot.log: line 339: ++: command not found
/boot/first-boot.log: line 340: +: command not found
/boot/first-boot.log: line 341: +: command not found
/boot/first-boot.log: line 342: +: command not found
/boot/first-boot.log: line 343: +: command not found
/boot/first-boot.log: line 344: +: command not found
/boot/first-boot.log: line 345: +: command not found
/boot/first-boot.log: line 346: +: command not found
/boot/first-boot.log: line 347: ++: command not found
/boot/first-boot.log: line 348: ++: command not found
/boot/first-boot.log: line 349: +: command not found
/boot/first-boot.log: line 350: 2020-11-05_17:57:00_UTC: command not found
/boot/first-boot.log: line 351: +: command not found
/boot/first-boot.log: line 352: +: command not found
/boot/first-boot.log: line 353: +: command not found
/boot/first-boot.log: line 354: +: command not found
/boot/first-boot.log: line 355: +: command not found
/boot/first-boot.log: line 356: +: command not found
/boot/first-boot.log: line 357: +: command not found
/boot/first-boot.log: line 359: $‘\E[90’: command not found
/boot/first-boot.log: line 359: 01m$: command not found
/boot/first-boot.log: line 359: 49: command not found
/boot/first-boot.log: line 359: 00m: command not found
/boot/first-boot.log: line 360: +: command not found
/boot/first-boot.log: line 361: +: command not found
/boot/first-boot.log: line 362: ++: command not found
/boot/first-boot.log: line 363: +: command not found
/boot/first-boot.log: line 364: syntax error near unexpected token Europe/Berlin' /boot/first-boot.log: line 364: OK (Europe/Berlin)’
When I ran /usr/local/bin/FireMotD –version I got
[19:49:59] openhabian@openHABianDevice:~$ /usr/local/bin/FireMotD --version
FireMotD v12.05.191019
I ran sudo /usr/local/bin/FireMotD -S & sudo /usr/local/bin/FireMotD --theme Gray
[19:54:21] openhabian@openHABianDevice:~$ sudo /usr/local/bin/FireMotD -S
[19:55:25] openhabian@openHABianDevice:~$ sudo /usr/local/bin/FireMotD --theme Gray
############### openHABianDevice ############################################
Ip = 192.168.0.51
Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 5.4.51-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.4
Uptime = 0 day(s). 0:2:35
CPU Usage = 0% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 0.73, 5m: 0.57, 15m: 0.24
Memory = Free: 7.12GB (92%), Used: 0.61GB (8%), Total: 7.73GB
Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
Root = Free: 11.36GB (82%), Used: 2.34GB (18%), Total: 14.32GB
Updates = 16 apt updates available.
Sessions = 0 session(s)
Processes = 134 running processes of 32768 maximum processes
When I ran ip route get 8.8.8.8 | head -1 | grep -Po ‘(?<=src )(\d{1,3}.){4}’ | xargs I got this output
[19:56:22] openhabian@openHABianDevice:~$ ip route get 8.8.8.8 | head -1 | grep -Po ‘(?<=src )(\d{1,3}.){4}’ | xargs
192.168.0.51
So the IP address is now showing and I can access the online dashboard at the link http://192.168.0.51:8080/start/index but can’t be accessed at http://openhabiandevice:8080/
