Hello, recently upgraded to openHAB 2.1.0-1 and am now unable to access the web GUI via port 8080 or any port. Looks like the openhab2 service and the apache service are both running. Unsure what else to look at. Any suggestions?
Thanks.
[23:47:35] pi@openHABianPi:~$ sudo /bin/systemctl status openhab2.service
[sudo] password for pi:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Sun 2017-10-08 20:57:16 EDT; 2h 50min ago
Docs: http://docs.openhab.org
https://community.openhab.org
Main PID: 384 (karaf)
CGroup: /system.slice/openhab2.service
├─384 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
└─955 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab
[23:31:05] pi@openHABianPi:/var/lib/openhab2/etc$ curl localhost:8080
curl: (7) Failed to connect to localhost port 8080: Connection refused
[23:37:18] pi@openHABianPi:/var/lib/openhab2/etc$ ps aux | grep apache
openhab 955 0.1 3.1 325600 31308 ? Sl 20:57 0:12 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djetty.host=0.0.0.0 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Djava.endorsed.dirs=/usr/lib/jvm/java-8-oracle/jre/jre/lib/endorsed:/usr/lib/jvm/java-8-oracle/jre/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/java-8-oracle/jre/jre/lib/ext:/usr/lib/jvm/java-8-oracle/jre/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/usr/share/openhab2/runtime/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
pi 3032 0.0 0.1 5888 1952 pts/1 S+ 23:38 0:00 grep --color=auto apache
