I’ve got an Aeotech MultiSensor 6 (ZW100-C) which is currently bound to a Z-Stick Gen 5 Z-Wave Plus USB Controller but I don’t believe the initialization is completing properly.
After leaving it on for a few hours (USB powered for now), the node status is still “ALIVE GET_CONFIGURATION” and the logs are full of errors like this:
The node is however reporting the device battery, temp, lux, humidity and PIR correctly.
Am using the latest 1.8.0-snapshot zwave binding. One other thing I’ve noticed is the node name in Habmin appears as ZW100-A, I’m assuming the differences to the ZW100-C are subtle (perhaps just regional differences - UK here), but could there be some other mismatches that are causing issues?
Not sure if there’s anything else I can include here, do let me know if I can provide anything else.
The unsupported command class errors are fine - I’ve got a gen 5 device and see the same. Can’t comment on the other errors.
If its usb/mains powered it should complete its configuration quite quickly. Could it be a range problem? How far from the controller is it/are there other nearby nodes?
I have a Fibaro dimmer currently about a meter away, the controller is about 3 metres away from both. The sensor has been reporting updates hourly overnight (along with the same errors periodically), node status remains the same.
First time I’ve ever tried to run openhab in debug mode, am getting this: Launching the openHAB runtime in debug mode... ERROR: transport error 202: bind failed: Address already in use ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510) JDWP exit error AGENT_ERROR_TRANSPORT_INIT(197): No transports initialized [../../../src/share/back/debugInit.c:750] FATAL ERROR in native method: JDWP No transports initialized, jvmtiError=AGENT_ERROR_TRANSPORT_INIT(197) Aborted (core dumped)
It looks like you might already have an instance of OH running, but that’s just a guess… Use ps or top to make sure there’s no other processes running (or task manager on windows).
Some points to note:
I excluded > factory reset > included the sensor prior to running
The sensor is Node 8, Node 4 is a Fibaro Dimmer 2
At 14:01:22 I added the following to default.items
Number Sensor_LivingRoom_Battery "Sensor Living Room Battery [%s %%]" {zwave="8:command=battery"} Number Sensor_LivingRoom_Temperature "Living Room Temp [%.1f C]" <temperature> {zwave="8:0:command=sensor_multilevel,sensor_type=1"} Number Sensor_LivingRoom_Lux "Living Room Lux [%.0f Lux]" <lux> {zwave="8:command=sensor_multilevel,sensor_type=3"} Number Sensor_LivingRoom_Humidity "Living Room Humidity [%.0f %%]" <water> {zwave="8:command=sensor_multilevel,sensor_type=5"} Contact Sensor_LivingRoom_PIR "Living Room PIR" <pir> {zwave="8:command=sensor_binary,respond_to_basic=true"}
This is perfectly normal - it always occurs when a message is sent from the device that the controller didn’t request. It’s not an error, just a debug message.
Thanks a lot for looking Chris, I’m not sure it is fine, Heal Status is now FAILED during UPDATEROUTESNEXT and Node Stage is now FAILED DONE.
I’ve updated the log file with the additional entries at the bottom. As you’ll see I’ve back to normal, I’ll go back to debug and update it again in a couple of hours.
I’ve tried running it on both, it’s currently on batteries though, I’ve got it on debug mode now and OpenHAB received updates from the sensor without me waking it, then shortly after it was marked as dead again.
When you included it, was it included into the network using batteries, or USB. It MUST be done on batteries if you are using batteries - you can’t swap between batteries and USB. I suspect this is ok from what I see in the log, but it’s worth confirming.
NODE 8: Is currently marked as failed by the controller!
is a problem. It means that the controller thinks the device is dead - so it’s not even an OH issue…
I might change my earlier statement that I think the device inclusion was ok. I don’t think I’ve seen the controller mark a battery device as failed, so I suspect it’s possible that maybe this was included on mains, and is now running batteries?
