Hi all,
I would love to contribute with bindings for Bticino for openHAB2 but however the whole SDK drives me crazy. Basically, I followed the instructions using Eclipse Installer to install Eclipse Oxygen (tried both 32 and 64 Bit) and different combinations of the of the available packages (openHAB development, ESH+OH2 Core Bundles, openHAB 2 Add-ons). However, after downloading tons of megabytes, cloning repositories etc. the result is still the same
–> Eclipse shows literally thousands of errors. Sometimes closing, refreshing etc. projects helps a little bit to reduce the number of errors but this does not work out. It seems that the dependency resultion is not working since i get many errors on unresolved package names.
After trying several times with different settings, I tried to isolate a single binding project (e.g., the one for onkyo AV receivers) by separating the Maven module. However, this didn’t worked either since dependencies to the core can’t be resolved. I checked the maven dependencies but there were no indications on how the dependency to the core is resolved at all. So building a single binding “in isolation” by just referencing the parent project in the pom simply doesn’t work either.
So any suggestions on how to get a clean IDE for starting binding development?
