today I copy/pasted two different items from different web sites. Both use http binding + JS transformation and both fail when loading the *.js files in my /etc/openhab2/transform folders. No clue why. openhab.log says:
An error occurred while loading script
Furthermore I see that the http binding works fine and the result is returned correctly, but then thrown as an exception when loading the js file. Seems it cannot find it or permissions are wrong. Latter are correct.
Maybe too easy, but as there is no info yet about it from your side:
You did install http binding and js transformation service successful?
The error without a file in that folder seems valid.
For the situation when is files are present:
Maybe you can post the is files here, so we can have a look at them too?
No problem, mistakes happen every day. None of us is perfect.
May I ask you to mark your last post as solution?
So others with javascript transformation problems can see the final result of this topic directly in the first post.
