- Platform information:
- Hardware: RBP4
- OS: OH
- Java Runtime Environment: Java 8
- openHAB version: 2.5.9
For reading out my smartmeter I use a python script via a rule which gets called every 10 seconds.
Unfortunately this gets broken very often and I get a whole bunch of the following mqtt exceptions:
2020-10-26 14:33:04.550 [ERROR] [.moquette.broker.NewNettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=SmartMeterHousePythonClient
at io.moquette.broker.MQTTConnection.handleConnectionLost(MQTTConnection.java:255) ~[?:?]
at io.moquette.broker.NewNettyMQTTHandler.channelInactive(NewNettyMQTTHandler.java:82) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:257) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:243) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:236) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.MQTTMessageLogger.channelInactive(MQTTMessageLogger.java:109) [bundleFile:?]
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:393) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:358) [bundleFile:4.1.42.Final]
at io.netty.channel.ChannelInboundHandlerAdapter.channelInactive(ChannelInboundHandlerAdapter.java:81) [bundleFile:4.1.42.Final]
at io.moquette.broker.AutoFlushHandler.channelInactive(AutoFlushHandler.java:90) [bundleFile:?]
at io.netty.handler.timeout.IdleStateHandler.channelInactive(IdleStateHandler.java:278) [bundleFile:4.1.42.Final]
at io.moquette.broker.InflightResender.channelInactive(InflightResender.java:123) [bundleFile:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1417) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:913) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe$8.run(AbstractChannel.java:819) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:510) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:518) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
My python script is the following:
#!/usr/bin/env python
# encoding: utf-8
Copyright by Alex Mack 2020
import sys
import os
import datetime
import serial #needs an 'sudo -H pip install pyserial' if used via exec binding
import time
import re
import paho.mqtt.client as paho #needs an 'sudo -H pip install paho-mqtt' if used via exec binding
#openhab remove commands
#sudo apt-get purge openhab2*
#sudo rm /etc/apt/sources.list.d/openhab2.list
# SML regexes
complete_message_regex = '1b1b1b1b01010101.*1b1b1b1b.{8}'
meter_108_regex = '77070100010800ff.{30}(.{8})01'
meter_208_regex = '77070100020800ff.{30}(.{8})01'
meter_167_regex = '77070100100700ff.{14}(.{4})01'
#MQTT Broker setup
brokerIP="192.168.1.27"
brokerPort=1883
brokerUser="Psst"
brokerPwd="notTellingThatOne"
#Connected Serial Device Address
serialDevice="/dev/ttyUSB1"
#Refreshing period in seconds
refreshSeconds=1
consumptionPublishedId=0
supplyPublishedId=0
currentConsumptionPublishedId=0
# Wait for mqtt client to close properly
MQTTClientConnectionClosed=0
def on_publish(client, userdata, result):
if result == 3:
#print "closing"
disconnectMQTTClient(client)
def disconnectMQTTClient(client):
client.loop_stop()
client.disconnect()
MQTTClientConnectionClosed=1
def on_disconnect():
print "disconnected"
def setupMQTTBrokerClient():
client = paho.Client("SmartMeterHousePythonClient")
client.username_pw_set(brokerUser, brokerPwd)
client.connect(brokerIP, brokerPort)
client.on_publish = on_publish
client.on_disconnect = on_disconnect
client.loop_start()
return client
def main():
ser = serial.Serial(serialDevice, baudrate=9600, bytesize=8, parity='N', stopbits=1, timeout=0 )
tty_error = 0
searching = 1
numberOfTrials = 0;
client1 = setupMQTTBrokerClient()
if tty_error == 0:
while searching > 0 and numberOfTrials <= 100:
numberOfTrials += 1
data = ser.read(4096)
data = data.encode('hex').lower()
if re.match(complete_message_regex, data):
m108 = re.search(meter_108_regex, data)
m208 = re.search(meter_208_regex, data)
m167 = re.search(meter_167_regex, data)
if m208:
d208 = abs(int(m208.group(1),16)/10000.0)
if d208 is not None:
ret = client1.publish("smartmeters/house/totalSupply",d208)
supplyPublishedId=ret[1]
print "Gesamt-Einspeisung:{:.2f} KWh".format(d208)
if m108:
d108 = abs(int(m108.group(1),16)/10000.0)
if d108 is not None:
ret = client1.publish("smartmeters/house/totalConsumption",d108)
consumptionPublishedId=ret[1]
print "Gesamtverbrauch: {:.3f}".format(d108)
if m167:
d167 = abs(int(m167.group(1),16)/10.0)
if d167 is not None:
ret = client1.publish("smartmeters/house/currentConsumptionTotal",d167)
currentConsumptionPublishedId=ret[1]
print "Aktueller Gesamtverbrauch Haus: {:.3f}".format(d167)
if m208 and m108 and m167:
searching = 0;
#Current Usage calculated by openhab persistence
#if m167:
# d167 = int(m167.group(1),16)
# print "Aktueller Verbrauch: {:.2f}".format(d167)
time.sleep(refreshSeconds)
#At this point we should have sent out all messages or aborted due to to much tries
while MQTTClientConnectionClosed != 1:
print "Closing connection manually"
disconnectMQTTClient(client1)
if __name__ == '__main__':
main()
I thought that this has something todo with not closing the mqtt client properly, that´s why I recently built in the while with the definite closing but it didn´t help
I would really appreciate any help
