i am just tried to setup openhab in an Docker environment on my newly bought unraid server.
Everything is working fine, however i am experience this strange behaviour with Hue connected Items:
- Platform information:
- Hardware: x86/16GB Ram/20 GB
- OS: unraid Server with Linux 4.19.56-Unraid x86_64 Kernel
- Java Runtime Environment: I think this is included in the Docker Container
- openHAB version: openhab/openhab:2.5.0.M1-amd64-debian; openhab/openhab:2.4.0-amd64-debian both from https://hub.docker.com/r/openhab/openhab/
- Issue of the topic: see above
- Please post configurations (if applicable):
- Items configuration related to the issue
Switch Wohnzimmer_Leseleuchte "Leseleuchte" { channel="hue:0220:00178827902c:Zigbee_Wohnzimmer_Leseleuchte:brightness" }
- Sitemap configuration related to the issue
sitemap test label="Test" {
Frame {
Switch item=Wohnzimmer_Leseleuchte
- Services configuration related to the issue
Bridge hue:bridge:00178827902c "Bridge: Philips Hue" [ ipAddress="philips-hue", userName="VViZCo1BH3-bAyB4jRHJQvG-39BIJsfR0kWrRtYB" ] {
0220 Zigbee_Wohnzimmer_Leseleuchte "Zigbee: Wohnzimmer Leseleuchte" @ "Wohnzimmer" [ lightId="49" ]
- If logs where generated please post these here using code fences:
2019-10-12 20:37:46.749 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer_Leseleuchte' received command OFF
2019-10-12 20:37:46.750 [nt.ItemStatePredictedEvent] - Wohnzimmer_Leseleuchte predicted to become ON
2019-10-12 20:37:49.094 [vent.ItemStateChangedEvent] - Wohnzimmer_Leseleuchte changed from ON to OFF
2019-10-12 20:40:44.545 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer_Leseleuchte' received command ON
2019-10-12 20:40:44.546 [nt.ItemStatePredictedEvent] - Wohnzimmer_Leseleuchte predicted to become OFF
2019-10-12 20:40:56.570 [vent.ItemStateChangedEvent] - Wohnzimmer_Leseleuchte changed from OFF to ON
2019-10-12 20:41:22.961 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer_Leseleuchte' received command OFF
2019-10-12 20:41:22.961 [nt.ItemStatePredictedEvent] - Wohnzimmer_Leseleuchte predicted to become ON
2019-10-12 20:41:26.670 [vent.ItemStateChangedEvent] - Wohnzimmer_Leseleuchte changed from ON to OFF
2019-10-12 20:41:30.146 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer_Leseleuchte' received command ON
2019-10-12 20:41:30.147 [nt.ItemStatePredictedEvent] - Wohnzimmer_Leseleuchte predicted to become OFF
2019-10-12 20:41:36.698 [vent.ItemStateChangedEvent] - Wohnzimmer_Leseleuchte changed from OFF to ON
Hopefully this is just some dumb mistake i made. I searched for something similar, however i couldn’t find anything at all.
Thanks in advance
Cheers
Andreas
