addons.cfg
The installation package of this openHAB instance
Note: This is only regarded at the VERY FIRST START of openHAB
Note: If you want to specify your add-ons yourself through entries below, set the package to “minimal”
as otherwise your definition might be in conflict with what the installation package defines.
Valid options:
- standard : Standard setup for normal use of openHAB
- minimal : Installation of core components, but no UIs or other add-ons. Use this for special headless setups.
- demo : A pre-configured demo setup which can be used for demonstration.
package = standard
Access Remote Add-on Repository
Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons. (default is true)
#remote = true
A comma-separated list of automation services to install (e.g. “automation = groovyscripting”)
automation = groovyscripting,jythonscripting
A comma-separated list of bindings to install (e.g. “binding = knx,sonos,zwave”)
#binding =
binding = amazonechocontrol,astro,bluetooth,chromecast,darksky,dmx,deconz,dscalarm,enigma2,exec,feed,gpstracker,harmonyhub,hpprinter,http,hue,icloud,mqtt,network,ntp,shelly,squeezebox,systeminfo,telegram,unifi,zwave
amazonechocontrol ,plex1.wol1,
A comma-separated list of miscellaneous services to install (e.g. “misc = openhabcloud”)
misc = openhabcloud,hueemulation
,hueemulation
A comma-separated list of persistence services to install (e.g. “persistence = jpa,rrd4j”)
persistence = mapdb,rrd4j
A comma-separated list of transformation services to install (e.g. “transformation = jsonpath,map”)
transformation = bin2json,exec,javascript,jsonpath,map,regex
A comma-separated list of UIs to install (e.g. “ui = basic,habpanel”)
ui = basic,habpanel
A comma-separated list of voice services to install (e.g. “voice = googletts,marytts”)
#voice =
I have it this way
UNIFI.things
Bridge unifi:controller:home “UniFi Controller” @ “UNIFI” [ host=“192.168.0.128”, port=8443, username=“χχχχχ”, password=“χχχχχχχ”, refresh=10 ]
Thing wirelessClient mobileChris "UNIFI Mobile Chris" @ "UNIFI" [ cid="192.168.0.10" , site="default", considerHome=180 ]
Thing wirelessClient mobileOlga "UNIFI Mobile Olga" @ "UNIFI" [ cid="χχχχχχχχχχχχ" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient mobileAfroditi "UNIFI Mobile Afroditi" @ "UNIFI" [ cid="192.168.0.12" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient mobileMeri "UNIFI Mobile Meri" @ "UNIFI" [ cid="192.168.0.13" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient mobileMaria "UNIFI Mobile Maria" @ "UNIFI" [ cid="192.168.0.14" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient mobileElias "UNIFI Mobile Elias" @ "UNIFI" [ cid="192.168.0.15" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient xiaomiTVBox_Milia "UNIFI Xiaomi TV Box" @ "UNIFI" [ cid="192.168.0.19" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient amazonFireTVBox_Milia "UNIFI Amazon Fire TV" @ "UNIFI" [ cid="192.168.0.29" , site="Chris Kallas", considerHome=180 ]
Thing wirelessClient mobileKostakis "UNIFI Mobile Kostakis" @ "UNIFI" [ cid="192.168.0.120", site="Chris Kallas", considerHome=180 ]
