I just upgraded to OpenHab v5.2.1.
The Bridge reports always as offline and the openhab admin console suggess it is a configuration error / authentication problem. Note that the authentication has not changed (and I can login with the same credentials via the https interface).
I use the following .things to configure the bridge.
Bridge unifi:controller:home "UniFi Controller" [ host="unifi-network-application", port=8443, username="<hidden>", password="<hidden>", refresh=10 ] {
Thing wirelessClient phone1 "Phone 1" [ cid="<hidden>", considerHome=180 ]
I am using unifi-network-application:10.4.57
I did enable Trace logging on the addon and that looks not helpful. The only thing in the log I see (when disabling and re-enabling the bridge):
2026-08-19 02:29:29.121 [TRACE] [rk.handler.NetworkRefreshCoordinator] - Bridge session not available yet; skipping refresh
2026-08-19 02:29:31.591 [DEBUG] [work.handler.UniFiClientThingHandler] - Initializing the UniFi Client Handler with config = UniFiClientConfig{cid: '<hidden>', site: '', considerHome: 180}
2026-08-19 02:29:39.121 [TRACE] [rk.handler.NetworkRefreshCoordinator] - Bridge session not available yet; skipping refresh
Any suggestion how I can fix this issue?
Thanks!
