I just updated to 3.1.0.M2 - Milestone Build this morning while trying to resolve a frontail problem, and I cannot get the Unifi binding working.
HANDLER_CONFIGURATION_PENDING
My things were created via text file, but I removed them, removed the binding, reinstalled the binding and manually created the thing in MainUI and still receive the same error.
I’m not sure if I touched anything else that would cause the problem. I’m going to try to change the log level later when I have a chance, but thought I’d relay the issue if anyone else has experienced.
I experienced this also after upgrading to 3.1. For me it was sufficient to add "unifios=“false” to my things file. From UI I needed to enable, save, disable, save.
