I’ve created this simple sitemap with a transform.
sitemap home label="Mein Zuhause" {
Frame label="Erdgeschoss" icon="groundfloor" {
Text item=Energy_Consumption_CentralHeater label="Zentralheizung [JS(Wh_to_kWh.js):%.2f kWh]"
And this little JS
// Transforms Wh Values to kWh
(function(i) {
return (parseFloat(i)/1000.0);
})(input)
But in Simple UI, the unit of the value (kWh) is not printed.
Any suggestions on this?
Bests
Pascal
vzorglub
(Vincent Regaud)
2
Please post your item definition. I am sure we can make good use of the UoM here
Number Energy_Consumption_CentralHeater "Zentralheizung [%.2f Wh]" <energy> (BM,gCounters) { channel="knx:device:bridge:bm_switch_actuator_1:energy_consumption_centralheater" }
vzorglub
(Vincent Regaud)
4
Good
Now change this to:
Number:Energy Energy_Consumption_CentralHeater "Zentralheizung [%.2f Wh]" <energy> (BM,gCounters) { channel="knx:device:bridge:bm_switch_actuator_1:energy_consumption_centralheater" }
In your sitemap:
Text item=Energy_Consumption_CentralHeater label="Zentralheizung [%.2f kWh]"
That’s it. Simple as that
Even if this is a realy nice solution for the initial problem (THX for that), it doesn’t answer my question.
vzorglub
(Vincent Regaud)
6
Text item=Energy_Consumption_CentralHeater label="Zentralheizung [JS(Wh_to_kWh.js):%.2f] kWh"
I think that would have worked
That was also my first idea. But it can’t parse the sitemap if you place the Unit behind the Bracket.
