@Jeevs
ok, thanks for your feedback, i thought that who already have radiators with humidity support, why not add it. for who doesn’t have this support, item graph and label are not displayed.
to add this, i had to rebuild half of the widget, but now is better than before, especially for temperature alignment when there were no title of the card.
let me know if is okay also for you.
Wow thank you so much for the hard work there @rubenfuser!
Works like an absolute charm just copy and paste!
Many thanks once again for the rapid turn around on this
Hi Ruben, thanks so much for this cool thing. Yesterday I played around with it a little. It works well with my FRITZ DECT Controls for showing the current Setpoint as well as actual temp. But I don’t get the nice graphs! What do I do wrong or which prerequisits have to be put in place?
Thanks, Ralph.
mmm Graph is based on actual temp item…and the item has to be Measurement, Temperature as properties. can you check if you’ve set both correctly?
seems to be okay…is it member of the radiator group?
Thanks for the reply. In the meantime I switched to Home Assistant.
