Hello community! I’m trying to build a universal Rollershutter widget for every rollershutter model.
This is the first release, so there could be some bugs or options to be fine tuned, so feel free to tell me what are issues you will find.
This widget looks into “Model” scheme, find some defined tags (described below) and automatically show/hide widget options.
This widget is the first of the package of widgets that i would like to distribute. My idea is to develope a set of universal widgets suitable for everyone and usable for different brand devices.
Version 2.0 need some more settings, like creating 3 more items to make scheduler working.
Follow these steps to enable scheduler:
- Create from the UI “Items” → “textual definition”:
Group gRollershuttersBathroom "Rollershutters Bathroom"
Switch AutomationRollershutterBathroom "Automation Rollershutter Bathroom" <switch> (gRollershuttersBathroom) [Control,Level]
DateTime ClosureRollershutterBathroomWeekly "Closure Rollershutter Bathroom Weekly" <time> (gRollershuttersBathroom) [Point,Timestamp] {stateDescription=" "[pattern= "%1$tH:%1$tM", readOnly= "true"]}
DateTime OpeningRollershutterBathroomWeekly "Opening Rollershutter Bathroom Weekly" <time> (gRollershuttersBathroom) [Point,Timestamp] {stateDescription=" "[pattern= "%1$tH:%1$tM", readOnly= "true"]}
- Then go to Developer tools –>API Explorer–>Items–>PUT (updates the state of an item)–>TRY IT OUT
Insert the name of the item:
- ClosureRollershutterBathroomWeekly
as “valid state” put 00:00
same fo the other item:
- OpeningRollershutterBathroomWeekly
Now create the rule, setting it properly with your Rollershutter item:
For automatic opening:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: OpeningRollershutterBathroomWeekly
type: timer.DateTimeTrigger
conditions:
- inputs: {}
configuration:
offset: 0
type: ephemeris.WeekdayCondition
- inputs: {}
configuration:
itemName: AutomationRollershutterBathroom
state: ON
operator: =
type: core.ItemStateCondition
- inputs: {}
configuration:
itemName: TapparellaBagno_RollerShutter (change this with your rollershutter item name)
state: "0"
operator: "!="
actions:
- inputs: {}
configuration:
command: UP
type: core.ItemCommandAction
For automatic closure:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: ClosureRollershutterBathroomWeekly
conditions:
- inputs: {}
configuration:
offset: 0
- inputs: {}
configuration:
state: ON
operator: =
- inputs: {}
configuration:
state: "100"
operator: "!="
actions:
- inputs: {}
configuration:
command: DOWN
Then repeat above steps for each of your rollershutters.
Screenshots
Version 2
- Enhanced version of the Universal rollershutter Widget
Changelog
- Added the slider to control rollershutter better
- Moved preset buttons to the “Control” block
- Added the scheduler setting (thanks to Timepicker widget) with on/off switch to enable/disable scheduler
- Chart visible only when button is pressed
- Changed layout of control buttons to vertical style.
- General recolor (Thanks to @Fabrizio_Valtorta)
Version 0.1
- initial release
Changelog
- changed the YAML to be suitable for single rollershutter item
- fixed missing translation in english
Resources
uid: Universal Rollershutter Card
tags: []
props:
parameters:
- context: Text
description: Title of the card
label: Title
required: false
type: TEXT
- context: item
description: Rollershutter Item
label: Rollershutter Item
required: true
type: TEXT
- context: item
description: Enable Schedule
label: Enable Schedule Item
required: false
type: TEXT
- context: item
description: Opening Time
label: Opening Time Item
required: false
type: TEXT
- context: item
description: Closure Time
label: Closure Time Item
required: false
type: TEXT
timestamp: Nov 7, 2022, 8:19:09 PM
component: f7-card
style:
background: '=themeOptions.dark === "dark" ? "rgb(40, 40, 40)" : "rgb(240, 240, 240)"'
box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.3)
margin-left: 5px
margin-right: 5px
slots:
default:
- component: f7-card-content
style:
position: relative
z-index: 3
slots:
default:
- component: f7-row
style:
margin-bottom: -10px
margin-left: 0px
margin-right: 0px
slots:
default:
- component: f7-col
style:
margin-left: 0px
margin-right: 0px
width: 60px
slots:
default:
- component: oh-icon
height: 50px
icon: iconify:ic:twotone-roller-shades
style:
color: orange
- component: f7-col
style:
margin-left: 60px
margin-right: 0px
position: absolute
width: 80%
slots:
default:
- component: f7-row
slots:
default:
- component: Label
style:
color: '=themeOptions.dark === "dark" ? "white" : "black"'
font-size: 15px
font-weight: 500
text: =props.rollerTitle
- component: f7-row
style:
align-items: right
display: flex
flex-direction: row
slots:
default:
- component: f7-chip
style:
background: orange
color: black
font-weight: 500
text: '=items[props.groupItem].state == "100" || items[props.groupItem].displayState == "100" ? "Closed" : items[props.groupItem].state == "0" || items[props.groupItem].displayState == "0" ? "Open" : items[props.groupItem].state + "% closed" || items[props.groupItem].displayState + "% closed"'
- component: f7-col
style:
margin-left: 0px
margin-right: 0px
width: 26px
slots:
default:
- component: oh-link
action: command
actionCommand: UP
actionItem: =props.groupItem
iconColor: orange
iconF7: arrow_up_circle
iconSize: 28
style:
z-index: 98
action: command
actionCommand: STOP
iconF7: stop_circle
iconSize: 28
style:
z-index: 98
action: command
actionCommand: DOWN
iconColor: orange
iconF7: arrow_down_circle
iconSize: 28
style:
z-index: 98
class: align-items-center alignt-text-center justify-content-center
style:
margin-left: 15px
margin-right: 15px
position: relative
z-index: 2
visible: =(vars.PresetVisible) == true
slots:
default:
- component: f7-row
slots:
default:
- component: oh-slider
color: orange
item: =props.groupItem
max: 100
min: 0
step: "1"
style:
background: trasparent
color: black
font-size: 13px
- component: f7-row
style:
margin-top: 15px
slots:
default:
- component: oh-button
action: command
actionCommand: 25
round: true
style:
background: '=items[props.groupItem].state >= "20" && items[props.groupItem].state <= "30" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 25
action: command
actionCommand: 40
round: true
style:
background: '=items[props.groupItem].state >= "35" && items[props.groupItem].state <= "45" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 40
action: command
actionCommand: 50
round: true
style:
background: '=items[props.groupItem].state >= "45" && items[props.groupItem].state <= "55" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 50
action: command
actionCommand: 75
round: true
style:
background: '=items[props.groupItem].state >= "70" && items[props.groupItem].state <= "80" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 75
action: command
actionCommand: 90
round: true
style:
background: '=items[props.groupItem].state >= "85" && items[props.groupItem].state <= "95" ? "orange" : "rgb(210, 210, 210)"'
color: black
z-index: 98
text: 90
class: display-flex align-items-center alignt-text-center justify-content-center
style:
margin-left: 0px
margin-right: 0px
margin-top: -10px
position: relative
z-index: 1
visible: =(vars.ScheduleVisible) == true
slots:
default:
- component: f7-row
style:
width: 300px
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
text-decoration: underline
text-underline-offset: 4px
text: Opening Time
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
actionItem: =(props.OpeningTimeItem)
style:
--f7-button-text-color: orange
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.OpeningTimeItem].state === 'NULL') || !props.OpeningTimeItem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.OpeningTimeItem].state).format('hh'): dayjs(items[props.OpeningTimeItem].state).format('HH'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(-1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 20px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ":"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.OpeningTimeItem].state === 'NULL') || !props.OpeningTimeItem) ? '?': dayjs(items[props.OpeningTimeItem].state).format('mm'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.OpeningTimeItem].state).add(-1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 100px
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 100px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
text: Closure Time
- component: f7-row
slots:
default:
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
actionItem: =(props.ClosureTimeItem)
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.ClosureTimeItem].state === 'NULL') || !props.ClosureTimeItem) ? '?': props.timeFormat == '12h' ? dayjs(items[props.ClosureTimeItem].state).format('hh'): dayjs(items[props.ClosureTimeItem].state).format('HH'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(-1, 'hour').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
- component: f7-col
style:
width: 20px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ":"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 20px
text: ""
- component: f7-col
style:
width: 40px
slots:
default:
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▲
- component: f7-row
style:
height: 30px
slots:
default:
- component: Label
style:
font-size: 15px
text-align: center
width: 40px
text: "=(((items[props.ClosureTimeItem].state === 'NULL') || !props.ClosureTimeItem) ? '?': dayjs(items[props.ClosureTimeItem].state).format('mm'))"
- component: f7-row
style:
height: 30px
text-align: center
slots:
default:
action: command
actionCommand: =(dayjs(items[props.ClosureTimeItem].state).add(-1, 'minute').format('YYYY-MM-DDTHH:mm:ss.ZZ'))
style:
font-family: u2400
font-size: 100%
width: 40px
text: ▼
style:
margin-bottom: -50px
margin-left: 15px
margin-right: 15px
margin-top: -50px
position: relative
z-index: 0
visible: =(vars.ChartVisible) == true
slots:
default:
- component: oh-chart
chartType: day
options:
backgroundColor: transparent
periodVisible: false
slots:
grid:
- component: oh-chart-grid
containLabel: false
series:
- component: oh-time-series
barWidth: 1
color: orange
gridIndex: 0
type: bar
xAxisIndex: 0
yAxisIndex: 0
xAxis:
- component: oh-time-axis
axisPointer:
show: false
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
min: 0
name: " % closed"
- component: f7-card-footer
style:
background: rgb(245, 218, 137)
border-radius: 0 0 10px 10px
height: auto
slots:
default:
- component: f7-block
style:
bottom: 3px
display: flex
left: 0
position: absolute
slots:
default:
action: variable
actionVariable: PresetVisible
actionVariableValue: =! (vars.PresetVisible)
slots:
default:
icon: iconify:mdi:window-shutter-auto
style:
color: "=(vars.PresetVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
action: variable
actionVariable: ScheduleVisible
actionVariableValue: =! (vars.ScheduleVisible)
slots:
default:
icon: iconify:akar-icons:clock
style:
color: "=(vars.ScheduleVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
- component: oh-toggle
color: green
item: =props.EnableSchedule
style:
--f7-toggle-height: 20px
--f7-toggle-inactive-color: red
--f7-toggle-width: 40px
margin-left: 7px
margin-top: -2px
z-index: 98
action: variable
actionVariable: ChartVisible
actionVariableValue: =! (vars.ChartVisible)
slots:
default:
icon: iconify:ant-design:bar-chart-outlined
style:
color: "=(vars.ChartVisible ? 'rgb(255, 128, 0)' : 'rgb(106, 106, 106)')"
width: 25px
A very big thank to @Fabrizio_Valtorta and @Jeevs for help and feedbacks from all test done!
