Universal Toggle
I hereby present you my universal toggle widget. The widget can be used in three different ways:
  1. Toggle a single switch
  2. Toggle a number of similar switches (e.g. some light switches)
  3. Toggle a number of similar switches (like 2.) together with a main switch to toggle all switches at the same time
Note that the widget does not care what switches you give it when you are using it in mode 3. The way I described it is just the way I am using it/the way it is meant to be used.
This is what it looks like:
And in action:
universal_toggle
Configuration:
Title: Card title (leave empty for no title bar)
Footer: Card footer (leave empty for no footer) NOTE: There appears to be a bug that sometimes prevents the scrolling of the grouptoggle swiper slide that I filed here: oh-repeater does not work correctly to populate f7-swiper-slides in f7-swiper · Issue #840 · openhab/openhab-webui · GitHub Setting a card footer with an expression (as in the example) seems to “fix” this but unfortunately not reliably. Please let me know if this is also an issue for you or if you know how to fix it.
F7 Icon: The name of the icon that should be shown in the widget
Color: The color scheme to use for the widget
Main toggle item: The “main switch” for the group or just a single switch if no group is configured (leave empty if you only want to switch a group of items without main switch)
Group toggle array: The array of switches that should be shown on the second slide or the single slide if the Main toggle item is omitted. Syntax: “<Label shown above icon of item 1>”,“<Name of item 1>”|“<Label shown above icon of item 2>”,“<Name of item 2>”, repeat as needed (leave empty if you only need the main switch)
Resources
The Code:
uid: universal_toggle_v4
tags: []
props:
  parameters:
    - description: Title of the card
      label: Title
      required: false
      type: TEXT
    - description: The card footer
      label: Footer
      required: false
      type: TEXT
    - description: Name of the Icon (see https://framework7.io/icons/ for available icons)
      label: F7 Icon
      required: true
      type: TEXT
    - description: Color scheme for icons and toggles (see https://framework7.io/docs/color-themes.html for available color schemes)
      label: Color
      required: true
      type: TEXT
    - context: item
      description: Main toggle item (use for single toggle or as main switch for group)
      label: Item
      required: false
      type: TEXT
    - description: Group toggles (use as group with or without main toggle)
      label: Group toggle Array
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Aug 27, 2023, 5:49:59 PM
component: f7-card
  title: =(props.title)
slots:
  default:
    - component: f7-card-content
      slots:
        default:
          - component: f7-swiper
              init: true
              pagination: "=(props.maintoggle) && (props.grouptogglearray) ? true : false"
              params:
                pagination:
                  clickable: true
                slidesPerView: 1
              style:
                height: 175px
                width: 100%
            slots:
              default:
                - component: f7-swiper-slide
                    style:
                      height: 100%
                      width: 100%
                    visible: "=(props.maintoggle) ? true : false"
                  slots:
                    default:
                      - component: f7-col
                          class:
                            - display-flex
                            - flex-direction-column
                            - align-items-center
                            - justify-content-space-evenly
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                            - component: oh-link
                                action: toggle
                                actionItem: =props.maintoggle
                                actionCommand: ON
                                actionCommandAlt: OFF
                              slots:
                                default:
                                  - component: f7-icon
                                      color: '=items[props.maintoggle].state == "ON" ? props.color : items[props.maintoggle].state > 0 ? props.color : "gray"'
                                      f7: =props.icon
                                      size: '=(props.grouptogglearray) ? "100" : "120"'
                            - component: oh-toggle
                                colorTheme: =props.color
                                item: =props.maintoggle
                            - component: f7-block
                                style:
                                  display: '=(props.grouptogglearray) ? "block" : "none"'
                                  height: 35px
                    visible: "=(props.grouptogglearray) ? true : false"
                  slots:
                    default:
                          params:
                            direction: vertical
                            mousewheel: true
                            scrollbar:
                              hide: true
                            slidesPerView: 1
                          scrollbar: true
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                            - component: oh-repeater
                                for: item
                                fragment: true
                                in: =props.grouptogglearray.split("|")
                              slots:
                                default:
                                      style:
                                        height: 100%
                                        width: 100%
                                    slots:
                                      default:
                                        - component: f7-col
                                            class:
                                              - display-flex
                                            style:
                                              height: 100%
                                              width: 100%
                                          slots:
                                            default:
                                              - component: f7-block-title
                                                  style:
                                                    margin-bottom: -2px
                                                    margin-top: 10px
                                                slots:
                                                  default:
                                                    - component: Label
                                                        text: =loop.item.split("\"")[1]
                                                  action: toggle
                                                  actionItem: =(loop.item.split("\"")[3])
                                                  actionCommand: ON
                                                slots:
                                                  default:
                                                        color: '=items[loop.item.split("\"")[3]].state == "ON" ? props.color : "gray"'
                                                        f7: =props.icon
                                                  item: =(loop.item.split("\"")[3])
                                                  style:
                                                    display: '=(props.maintoggle) ? "block" : "none"'
                                                    height: 35px
    - component: f7-card-footer
      slots:
        default:
          - component: Label
              text: =props.footer
Please let me see screenshots of what you are using them for :slight_smile:
Forgot to mention that there is actually a fourth mode: if you pass a single item into the group array you get the functionality of a single switch (mode 1.) but with a label on top of the icon.
Your Widghets (also the washing machine and the dishwasher) looks very nice.
if my skills in openhab are better i sure will implement this to my project. Maybe some will work a tutorial out for this? :slight_smile:
Thank you Bernhard! You mean a tutorial for the widgets? I hope I wrote down everything you need to know in the first post. If you have any questions feel free to ask here!
First thank you :slightly_smiling_face:
You wanted some use case screenshot. That’s not much but I use it to control the power outlet of my pellet stove.
That thing consumes too much power while on standby (up to 15W) so I got a script that shut off the power when I’m done using it. But then when I want to start a fire, I need to turn the plug on first.
So I’m using your widget to turn the power plug on, get the status of it and the live power consumption.
I’m actually using a dummy switch so that one cannot turn the power plug off manually. I have a script that will turn it off automatically when the cool down cycle is finished (which I detect through the power consumption)
Here is what it looks like :
Nice thanks for sharing!
I just recently added one more widget to be able to temporarily disable my Adblocker on the network. As I have two Pi-holes in the network it would be a bit of a pain to do this for both instances separately. With a swipe to the right I can see the status of both individual Pi-hole instances (second screenshot):
Nice implementation!
I also want to use this to turn “ON” and “OFF” a switch item, that I have created. But I meet some problems. No matter how I click the toggle in UI, the state of my switch never changes:
    "link": "http://137.226.248.161:8080/rest/items/gateway_switch",
    "state": "OFF",
    "editable": true,
    "type": "Switch",
    "name": "gateway_switch",
    "label": "gateway_switch",
    "category": "",
    "tags": [],
    "groupNames": []
And the color of the icon does not change either.
Screenshot 2023-05-16 222616
Screenshot 2023-05-16 222637
Here is also how I configure the widget.
Can someone help me out? Thanks a lot!
The icon color only changes when the actual item state changes whereas the toggle will just react immediately when you touch it. So especially when autoupdate is set to false there may be a delay between the toggle and the icon color change. If the item does not change its state at all then the icon will remain grey and the toggle will go back to being grey as well after a short time. So to me it looks as if the device you want to control is not reacting. I’m not familiar with the json you posted on your previous post especially the „link“ part. Could you explain where this comes from?
Nice widget. Thank you
Unfortunately I have the following situation: the widget works in editor mode, if “run mode” is on. But the same cell will not work, if I open the same page using the main ui webpage. In this case, I only see the header, but no icon (cell is blank). On the other hand the widget works by using the openhab app.
Hm I never experienced this behaviour. Which browser do you use?
It was in chrome, but works after restarting openhab container. No idea why.
Thanks for this relay cool widget!
I have a suggestion for improvement:
Is it possible to make the icon also “clickable”, that you don´t need to push the toggle?
Hi Gorilla,
thank you for your feedback! I like the idea and I guess it should be easy to achieve. I‘ll see if I find a bit of time to look into it later that day.
I just updated the code in the first post. The Icons are now clickable as well. Thanks go to JustinG who brought me on the right track (in the end it was a little bit trickier than I thought). Thank again for proposing this change Gorilla.
Works fine. Thanks alot!
Thanks for that easy and very nice widget.
I have the situation, that I see some list bullet points in front of the swiper and the icon?
How can that be removed?
Thx
I’ve never seen this. Could you post a screenshot of you configuration please?
This is the configuration yaml
component: widget:universal_toggle_v4
  icon: f7:thermometer
  maintoggle: Buro_Raumtemperaturregler_1004_ABB700C733A4_Activate
and here goes the widget yaml itself
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
      label: Footer
      required: false
      type: TEXT
      label: F7 Icon
      required: true
      type: TEXT
      label: Color
      required: true
      type: TEXT
    - context: item
      label: Item
      required: false
      type: TEXT
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Sep 11, 2023, 1:07:08 PM
component: f7-card
slots:
  default:
      slots:
        default:
              init: true
              params:
                pagination:
                  clickable: true
                slidesPerView: 1
              style:
                height: 175px
                width: 100%
            slots:
              default:
                    style:
                      height: 100%
                      width: 100%
                  slots:
                    default:
                      - component: f7-col
                          class:
                            - display-flex
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                                action: toggle
                                actionCommand: ON
                              slots:
                                default:
                                      f7: =props.icon
                                style:
                                  height: 35px
                  slots:
                    default:
                          params:
                            direction: vertical
                            mousewheel: true
                            scrollbar:
                              hide: true
                            slidesPerView: 1
                          scrollbar: true
                          style:
                            height: 100%
                            width: 100%
                        slots:
                          default:
                                for: item
                                fragment: true
                              slots:
                                default:
                                      style:
                                        height: 100%
                                        width: 100%
                                    slots:
                                      default:
                                        - component: f7-col
                                            class:
                                              - display-flex
                                            style:
                                              height: 100%
                                              width: 100%
                                          slots:
                                            default:
                                                  style:
                                                    margin-bottom: -2px
                                                    margin-top: 10px
                                                slots:
                                                  default:
                                                    - component: Label
                                                  action: toggle
                                                  actionCommand: ON
                                                slots:
                                                  default:
                                                        f7: =props.icon
                                                  style:
                                                    height: 35px
      slots:
        default:
          - component: Label
              text: =props.footer
Hmmm, this looks simple enough. Only thing I notice is that you should simply use „thermometer“ without the „f7:“ prefix. Can you try if this makes a difference?
I guess the yaml is unchanged? Does it look like this on the saved page or only when you are in edit mode? In edit mode things sometimes don’t look right…
Wow…i did remove the f7: now it works! Thx
