hi arthur, can you add more props for changing the title into their own language (Jasność, Ciepło koloru, kolor).
I think it is better to change this in the widget code. In props you have to change it for every widget you add and in code only once.
I’m trying to use the Widget with a Hue Bridge. Unfortunately there is no Wifi Strength, Energy Consumption etc.
I’d love if the respective Numbers would be hidden if i don’t select an item, rather than showing “NaN”
