The database update mentioned above was performed a couple of hours ago, the newest version of the development binding is from 2017-06-18.
So the database changes have not made it yet into the binding. You need to wait
If you really have resetted (hard resetted) your controller, you need to start from scratch anyway, because all your devices are gone. A hard reset is almost never needed to solve zwave problems.
If your openHAB instance is unresponsive you should restore a backup (which you hopefully did make before updating as recommended in every update tutorial).
I performed a soft reset of the control. The zwave devices that have been present from the beginning are still present, online and responsive. I just can’t add anything new to the zwave network, not even a hard wired GE switch, which I have 6 of working just fine. I know they are in the database, but for some reason openhab will not import them when I put the system in discovery mode.
