I also see a potential problem with one of my remotes that is apparently also set to master. I tried associating the nodes to the groups of node5 and here’s the log of the failed operation (assigning node 2 to group 1, node 3 to group 3, node 4 to group 4, node 2 to group 9 and nodes 3 & 4 to group 10):
2019-04-11 10:39:09.107 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update received
2019-04-11 10:39:09.133 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set binding_cmdrepollperiod to 1500 (BigDecimal)
2019-04-11 10:39:09.135 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_9 to [node_2] (ArrayList)
2019-04-11 10:39:09.137 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [node_2] consolidated to {}
2019-04-11 10:39:09.139 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=9, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.140 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=9, name=null, profile1=null, profile2=null, associations=[node_2]]
2019-04-11 10:39:09.142 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.163 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.165 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=9, name=null, profile1=null, profile2=null, associations=[node_2]]
2019-04-11 10:39:09.166 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_2 to association group 9
2019-04-11 10:39:09.168 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=9, node=2
2019-04-11 10:39:09.170 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.172 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 35 priority from Config to Immediate
2019-04-11 10:39:09.175 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.176 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 35 to queue - size 1
2019-04-11 10:39:09.178 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.180 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 9
2019-04-11 10:39:09.181 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.183 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.184 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 36 priority from Config to Immediate
2019-04-11 10:39:09.186 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 36 to queue - size 2
2019-04-11 10:39:09.189 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.190 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_8 to null (null)
2019-04-11 10:39:09.192 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [] consolidated to {}
2019-04-11 10:39:09.193 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=8, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.195 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=8, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.197 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.213 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.215 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=8, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.216 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association group 8 contains no members. Clearing.
2019-04-11 10:39:09.218 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_REMOVE group=8, node=all
2019-04-11 10:39:09.220 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.221 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.222 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 37 priority from Config to Immediate
2019-04-11 10:39:09.224 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.225 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 37 to queue - size 3
2019-04-11 10:39:09.226 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.228 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 8
2019-04-11 10:39:09.230 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.231 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.233 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 38 priority from Config to Immediate
2019-04-11 10:39:09.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 38 to queue - size 4
2019-04-11 10:39:09.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_5 to null (null)
2019-04-11 10:39:09.239 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [] consolidated to {}
2019-04-11 10:39:09.240 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=5, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=5, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.255 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.257 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=5, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.258 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association group 5 contains no members. Clearing.
2019-04-11 10:39:09.259 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_REMOVE group=5, node=all
2019-04-11 10:39:09.260 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.262 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.263 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 39 priority from Config to Immediate
2019-04-11 10:39:09.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.266 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 39 to queue - size 5
2019-04-11 10:39:09.267 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.269 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 5
2019-04-11 10:39:09.270 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.271 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 40 priority from Config to Immediate
2019-04-11 10:39:09.274 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.276 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 40 to queue - size 6
2019-04-11 10:39:09.277 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.278 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_4 to [node_4] (ArrayList)
2019-04-11 10:39:09.279 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [node_4] consolidated to {}
2019-04-11 10:39:09.280 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.281 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[node_4]]
2019-04-11 10:39:09.283 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.289 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.290 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[node_4]]
2019-04-11 10:39:09.291 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_4 to association group 4
2019-04-11 10:39:09.293 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=4, node=4
2019-04-11 10:39:09.294 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.295 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.296 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 41 priority from Config to Immediate
2019-04-11 10:39:09.297 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.298 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 41 to queue - size 7
2019-04-11 10:39:09.299 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.300 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 4
2019-04-11 10:39:09.302 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.304 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.305 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 42 priority from Config to Immediate
2019-04-11 10:39:09.306 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.307 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 42 to queue - size 8
2019-04-11 10:39:09.308 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.309 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_7 to null (null)
2019-04-11 10:39:09.310 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [] consolidated to {}
2019-04-11 10:39:09.311 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=7, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.312 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=7, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.313 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.319 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.320 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=7, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.321 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association group 7 contains no members. Clearing.
2019-04-11 10:39:09.322 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_REMOVE group=7, node=all
2019-04-11 10:39:09.323 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.324 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.325 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 43 priority from Config to Immediate
2019-04-11 10:39:09.326 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.327 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 43 to queue - size 9
2019-04-11 10:39:09.328 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.330 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 7
2019-04-11 10:39:09.331 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.332 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.333 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 44 priority from Config to Immediate
2019-04-11 10:39:09.334 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.335 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 44 to queue - size 10
2019-04-11 10:39:09.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.338 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set action_failed to false (Boolean)
2019-04-11 10:39:09.339 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_6 to null (null)
2019-04-11 10:39:09.341 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [] consolidated to {}
2019-04-11 10:39:09.342 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=6, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.343 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=6, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.345 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.351 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.352 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=6, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.354 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association group 6 contains no members. Clearing.
2019-04-11 10:39:09.355 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_REMOVE group=6, node=all
2019-04-11 10:39:09.356 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.357 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.358 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 45 priority from Config to Immediate
2019-04-11 10:39:09.359 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.361 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 45 to queue - size 11
2019-04-11 10:39:09.362 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.363 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 6
2019-04-11 10:39:09.364 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.365 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.366 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 46 priority from Config to Immediate
2019-04-11 10:39:09.367 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.368 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 46 to queue - size 12
2019-04-11 10:39:09.370 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.371 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_1 to [node_2] (ArrayList)
2019-04-11 10:39:09.372 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [node_2] consolidated to {}
2019-04-11 10:39:09.373 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.375 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[node_2]]
2019-04-11 10:39:09.376 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.382 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.383 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[node_2]]
2019-04-11 10:39:09.384 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_2 to association group 1
2019-04-11 10:39:09.385 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=1, node=2
2019-04-11 10:39:09.386 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.387 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.388 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 47 priority from Config to Immediate
2019-04-11 10:39:09.390 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.392 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 47 to queue - size 13
2019-04-11 10:39:09.393 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.394 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 1
2019-04-11 10:39:09.395 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.396 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.397 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 48 priority from Config to Immediate
2019-04-11 10:39:09.399 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.400 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 48 to queue - size 14
2019-04-11 10:39:09.401 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.402 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set action_remove to false (Boolean)
2019-04-11 10:39:09.403 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_3 to [node_3] (ArrayList)
2019-04-11 10:39:09.405 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [node_3] consolidated to {}
2019-04-11 10:39:09.406 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=3, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.407 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=3, name=null, profile1=null, profile2=null, associations=[node_3]]
2019-04-11 10:39:09.408 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.414 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.415 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=3, name=null, profile1=null, profile2=null, associations=[node_3]]
2019-04-11 10:39:09.416 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_3 to association group 3
2019-04-11 10:39:09.417 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=3, node=3
2019-04-11 10:39:09.418 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.419 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.420 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 49 priority from Config to Immediate
2019-04-11 10:39:09.421 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.423 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 49 to queue - size 15
2019-04-11 10:39:09.424 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.425 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 3
2019-04-11 10:39:09.426 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.427 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.428 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 50 priority from Config to Immediate
2019-04-11 10:39:09.429 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.431 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 50 to queue - size 16
2019-04-11 10:39:09.432 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.433 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set binding_pollperiod to 3600 (BigDecimal)
2019-04-11 10:39:09.434 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling intialised at 3600 seconds - start in 813600 milliseconds.
2019-04-11 10:39:09.435 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_2 to null (null)
2019-04-11 10:39:09.436 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [] consolidated to {}
2019-04-11 10:39:09.437 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.438 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.440 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.446 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.447 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.448 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association group 2 contains no members. Clearing.
2019-04-11 10:39:09.450 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_REMOVE group=2, node=all
2019-04-11 10:39:09.451 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.452 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.453 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 51 priority from Config to Immediate
2019-04-11 10:39:09.454 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.456 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 51 to queue - size 17
2019-04-11 10:39:09.457 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.458 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 2
2019-04-11 10:39:09.459 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.460 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.462 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 52 priority from Config to Immediate
2019-04-11 10:39:09.463 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.464 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 52 to queue - size 18
2019-04-11 10:39:09.465 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.467 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set group_10 to [node_3, node_4] (ArrayList)
2019-04-11 10:39:09.468 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Association [node_3, node_4] consolidated to {}
2019-04-11 10:39:09.469 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Current members before update ZWaveAssociationGroup [index=10, name=null, profile1=null, profile2=null, associations=[]]
2019-04-11 10:39:09.470 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after config update ZWaveAssociationGroup [index=10, name=null, profile1=null, profile2=null, associations=[node_3, node_4]]
2019-04-11 10:39:09.471 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is master - forcing associations
2019-04-11 10:39:09.477 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Thing has no default associations
2019-04-11 10:39:09.478 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Members after controller update ZWaveAssociationGroup [index=10, name=null, profile1=null, profile2=null, associations=[node_3, node_4]]
2019-04-11 10:39:09.479 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_3 to association group 10
2019-04-11 10:39:09.481 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=10, node=3
2019-04-11 10:39:09.482 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.483 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 53 priority from Config to Immediate
2019-04-11 10:39:09.485 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.486 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 53 to queue - size 19
2019-04-11 10:39:09.487 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.488 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Adding node_4 to association group 10
2019-04-11 10:39:09.490 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_SET, group=10, node=4
2019-04-11 10:39:09.491 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.492 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.493 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 54 priority from Config to Immediate
2019-04-11 10:39:09.494 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.495 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 54 to queue - size 20
2019-04-11 10:39:09.496 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.498 [DEBUG] [protocol.commandclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GET group 10
2019-04-11 10:39:09.499 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY not supported
2019-04-11 10:39:09.500 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2019-04-11 10:39:09.501 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Bump transaction 55 priority from Config to Immediate
2019-04-11 10:39:09.502 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2019-04-11 10:39:09.503 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Added 55 to queue - size 21
2019-04-11 10:39:09.504 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-04-11 10:39:09.506 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set action_heal to false (Boolean)
2019-04-11 10:39:09.507 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update set action_reinit to false (Boolean)
2019-04-11 10:39:09.508 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update ignored node_id to 5 (BigDecimal)
2019-04-11 10:39:09.517 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:controller:node5' has been updated.
2019-04-11 10:39:09.549 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=group_10, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_9, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_8, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_5, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_4, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_7, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_6, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
So it appears that the ZWP10 documentation is incorrect in stating that the ZWP10 controller can be defined as secondary controller by pressing IN/EX three times during inclusion. If I’m getting it right, I now have 4 primary controllers in my network: the ZME E UZB1 stick plus the 3 Fakro ZWP10 remotes…
