CSC
(SC)
June 25, 2017, 4:30am
1
Hi @chris , I added a Zwave switch to openhab and the device appeared as unknown device. The device is a simple on/off 1 gang switch.
I’m using OpenHab 2 on Pi, where do I find the xml file? Once I gotten the xml file, can I just email you?
The binding seems ok, I can see the manufacturer name.
CSC
(SC)
June 25, 2017, 5:53am
2
Just to supplement, I found 1 of the configuration file here:
/var/lib/openhab2/zwave
but I added 2 different devices, I can’t find the xml of another device, anybody has any idea?
chris
(Chris Jackson)
June 25, 2017, 8:51am
3
There is information here on how to add devices into the database. It’s appreciated if you can do this yourself otherwise I could easily spend all my time updating the database ;).
What is the other device? Is it a battery device? If so, then it will need to be woken up a few times to allow the binding to read all the information from it.
CSC
(SC)
June 25, 2017, 9:35am
4
It’s a 1 gang switch from U-fairy. I noted the DB has the 2 gang switch.
Let me grab the debug log and upload here later
chris
(Chris Jackson)
June 25, 2017, 9:38am
5
Ah - so you mean both devices are the same type? I thought you meant you’d added two different devices…
Ok - thanks.
CSC
(SC)
June 25, 2017, 11:03am
6
One is Zooz zwave sensor, the other is zwave switch
CSC
(SC)
June 25, 2017, 12:45pm
7
seems like I cant upload zip file here, so I emailed you the file.
