New to this openHab but enjoying it so far. Now for the story:
- I managed to get openhabian (v1.2) installed!
- Got WIFI set up as AP to talk to lifx bulb – success
- Added lifx bulb to openhabian – success
- Added aeotec zwave dongle to openhabian – success
- Added aeotec 4in1 multisensor to openhabian – eventual success
- Added aeotec 6in1 multisensor to openhabian – success
- Failure to add aeotec nano dimmer (ZW111-B) – Its reported as an unknown device – I think is the same as this one http://products.z-wavealliance.org/products/2095 but the -B for AUS
From other posts I see there is a device database, I couldn’t find ZW111 in there and I’m not sure what is needed to create an entry but I’m up for trying. Below is the rest API output for the thing and a stack trace. Any ideas on where to head from here?
FWIW I tried updating openhab to the nightly but jetty started so I uninstalled and went back to 2.0
Infos:
I have this: http://openhabianpi:8080/rest/things/zwave:device:88bf0286:node7
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"label": "Z-Wave Node 7 (0086:0203:006F:1.2)",
"bridgeUID": "zwave:serial_zstick:88bf0286",
"configuration": {
"group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@1fee2d2": [],
"switchall_mode": "SWITCH_ALL_INCLUDE_ON_OFF",
"group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@15ea344": [],
"group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@1db99da": [],
"group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@1e603d3": []
"properties": {
"zwave_class_basic": "ROUTING_SLAVE",
"zwave_class_generic": "MULTILEVEL_SWITCH",
"zwave_frequent": "false",
"zwave_neighbours": "1",
"zwave_version": "1.2",
"zwave_listening": "true",
"zwave_plus_devicetype": "LIGHT_DIMMER_SWITCH",
"zwave_deviceid": "111",
"zwave_nodeid": "7",
"zwave_routing": "true",
"zwave_beaming": "true",
"zwave_class_specific": "POWER_SWITCH_MULTILEVEL",
"zwave_manufacturer": "134",
"zwave_devicetype": "515"
"UID": "zwave:device:88bf0286:node7",
"thingTypeUID": "zwave:device",
"channels": []
**Stack trace during startup:**
``` 2017-04-14 14:26:05.683 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-04-14 14:26:08.921 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-04-14 14:26:09.050 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-04-14 14:26:10.490 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-04-14 14:26:10.685 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-04-14 14:26:14.008 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2017-04-14 14:26:14.096 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-04-14 14:26:14.114 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-04-14 14:26:14.140 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.146 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.147 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.148 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.150 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.151 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-04-14 14:26:14.151 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-04-14 14:26:14.152 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-04-14 14:26:17.445 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-04-14 14:26:17.447 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 5: Node found
2017-04-14 14:26:17.450 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 6: Node found
2017-04-14 14:26:17.452 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 7: Node found
2017-04-14 14:26:17.454 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-04-14 14:26:17.456 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-04-14 14:26:17.458 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-04-14 14:26:17.460 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 4
2017-04-14 14:26:17.462 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-04-14 14:26:18.990 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 7: Device discovery could not resolve to a thingType! 0086:0203:006F::1.2
2017-04-14 14:26:18.998 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:88bf0286:node7' to inbox.
2017-04-14 14:26:19.001 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! 0086:0203:006F::1.2
2017-04-14 14:26:19.024 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:88bf0286:node6' to inbox.
2017-04-14 14:26:19.067 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Size error 4<>1 from config_255_4_wo
2017-04-14 14:26:19.102 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Node...
2017-04-14 14:26:23.428 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 7: Timeout while sending message. Requeueing - 0 attempts left!
2017-04-14 14:26:23.429 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 7: Got an error while sending data. Resending message.
2017-04-14 14:26:30.257 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-04-14 14:26:34.373 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-04-14 14:26:38.460 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:26:42.606 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:26:46.771 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:26:50.857 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:26:55.002 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:27:05.227 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:27:45.196 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:29:05.226 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:29:57.329 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 5: Already processed another send data request for this callback Id, ignoring.
2017-04-14 14:30:02.299 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 0 attempts left!
2017-04-14 14:30:43.480 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:30:43.681 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:31:27.840 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:31:28.039 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:31:41.082 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: Retries exceeded at PING
2017-04-14 14:33:44.516 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Initialising Thing Node...
2017-04-14 14:33:57.311 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 5: Already processed another send data request for this callback Id, ignoring.
2017-04-14 14:34:02.284 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=5, callback=31, payload=05 01 00
2017-04-14 14:35:52.731 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:35:52.932 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:37:05.214 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:37:57.401 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:37:57.474 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:37:59.945 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '45' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorRelativeHumidity' to handler for channel 'zwave:device:9bee998c:node2:sensor_relhumidity', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:38:02.154 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '23.5' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorTemperature' to handler for channel 'zwave:device:9bee998c:node2:sensor_temperature', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:38:03.098 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '1000' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorLuminance' to handler for channel 'zwave:device:9bee998c:node2:sensor_luminance', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:38:03.832 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '92' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BatteryLevel' to handler for channel 'zwave:device:9bee998c:node2:battery-level', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:38:04.471 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Size error 4<>1 from config_255_4_wo
2017-04-14 14:38:04.474 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Node...
2017-04-14 14:38:04.517 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Size error 4<>1 from config_255_4_wo
2017-04-14 14:38:04.519 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Node...
2017-04-14 14:42:03.452 [WARN ] [age.RequestNetworkUpdateMessageClass] - RequestNetworkUpdate not placed on stack.
2017-04-14 14:42:06.731 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:42:06.930 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:47:45.202 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-04-14 14:49:12.260 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.IllegalArgumentException: Illegal parameter size 5
at org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter.<init>(ZWaveConfigurationParameter.java:39)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveConfigurationCommandClass.processConfigurationReport(ZWaveConfigurationCommandClass.java:129)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveConfigurationCommandClass.handleApplicationCommandRequest(ZWaveConfigurationCommandClass.java:86)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:119)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:248)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208)[192:org.openhab.binding.zwave:2.0.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324)[192:org.openhab.binding.zwave:2.0.0]
2017-04-14 14:53:22.488 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:53:22.692 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:53:57.962 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '92' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BatteryLevel' to handler for channel 'zwave:device:9bee998c:node2:battery-level', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:53:58.162 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '1000' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorLuminance' to handler for channel 'zwave:device:9bee998c:node2:sensor_luminance', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:53:59.420 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '23.4' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorTemperature' to handler for channel 'zwave:device:9bee998c:node2:sensor_temperature', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:53:59.665 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '45' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_SensorRelativeHumidity' to handler for channel 'zwave:device:9bee998c:node2:sensor_relhumidity', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:57:43.039 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:57:43.260 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 14:59:34.265 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
2017-04-14 15:06:32.740 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 15:06:32.943 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_Alarm' to handler for channel 'zwave:device:9bee998c:node2:alarm_general', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.
2017-04-14 15:08:17.321 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'ZWaveNode2ZW0744InOneMultiSensorG5_BinarySensor' to handler for channel 'zwave:device:9bee998c:node2:sensor_binary', because no thing with the UID 'zwave:device:9bee998c:node2' could be found.```
