I am moving from the OpenHab ZigBee binding to deCONZ, because it should allow me to adjust the sensitivity of my Hue motion sensor (see my question here, if interested).
However I am unable to pair my Hue bulb with my ConBee2, which is likely because it is still paired with the Bitron Video ZigBee USB Funkstick, which I used with the ZigBee binding.
I suspect that I need to reset the bulb, but all instructions I found online for this require either a Hue hub, the Hue dimmer switch, or an Amazon Echo, which I do not have.
So how do I get the Hue back into “pairing mode” using either the ZigBee binding with the Bitron Video ZigBee USB Funkstick or the ConBee2?
