Unregular layout of cells in a page
I want to set-up a page which does not have the shape of regular matrix with m rows and n columns.
I would like to create something where the height of a cell is half of a cell next to it two of these half cells are placed in the same column.
Imagine it like this:
|     |  b1  |      |
| A   +------+   C  |
|     |  b2  |      |
That means that the height of cell b1 and b2 is half of the height of cell A or cell C.
b1 and b2 are placed one on the other.
A and C are larger cells.
Is this possible?
If yes, could you please send me some code snippet of the code (yaml?) to create this layout.
Thank you in advance.
Wolfgang
I just saw that my sketch was destroyed but I hope you understand the text description.
There are numerous ways to accomplish this, and the differences are pretty minor, I suspect for your use case. Basically 3 main choices are (in increasing order of difficulty in my opinion): basic component (e.g., the built-in row and column components), an html table, or an html grid.
Basic components:
Really, the break down you’ve got here is one row that has three columns in it, with the only wrinkle being that the middle column has two pieces (or, it’s own rows). That’s very easy to render with widget code:
uid: basicComponents
props:
  parameterGroups: []
  parameters: []
tags: []
component: f7-block
slots:
  default:
    - component: f7-row
        style:
          height: 150px
      slots:
        default:
          - component: f7-col
              style:
                height: 100%
                border: solid red
            slots:
              default:
                - component: Label
                    text: Cell A
          - component: f7-col
              style:
                height: 100%
                border: solid blue
            slots:
              default:
                - component: f7-row
                    style:
                      height: 50%
                      box-sizing: border-box
                      border: solid green
                  slots:
                    default:
                      - component: Label
                          text: Cell B1
                - component: f7-row
                    style:
                      height: 50%
                      border: solid green
                  slots:
                    default:
                      - component: Label
                          text: Cell B2
          - component: f7-col
              style:
                height: 100%
                border: solid yellow
            slots:
              default:
                - component: Label
                    text: Cell C
The only tricky parts of this configuration are 1) making sure you change the box-sizing of the two middle cells just because of some of the default styles of the f7-row and columns and 2) making sure you have a height style set on the row that contains all the columns (or some other parent elements). If there is no explicit height style for a parent element then the percentage styles of the inner pieces will not have a number to be a percentage of.
Table:
You can use any standard html tags in addition to the component names as component so you can build an html table with a couple of rowspan attributes:
uid: htmlTable
props:
  parameterGroups: []
  parameters: []
tags: []
component: f7-block
slots:
  default:
    - component: table
      slots:
        default:
          - component: tr
            slots:
              default:
                - component: td
                    rowspan: 2
                    style:
                      border: solid red
                  slots:
                    default:
                      - component: Label
                          text: Cell A
                - component: td
                    style:
                      border: solid green
                  slots:
                    default:
                      - component: Label
                          text: Cell B1
                - component: td
                    rowspan: 2
                    style:
                  slots:
                    default:
                      - component: Label
                          text: Cell C
          - component: tr
            slots:
              default:
                - component: td
                    style:
                      border: solid green
                  slots:
                    default:
                      - component: Label
                          text: Cell B2
Unlike the previous option, you can get away without setting any explicit sizes here and the table will shrink to the minimum possible size that still contains all the cell elements.
Grid:
The grid offers an extraordinary amount of control of the ratios and placements and as a result of its complexity can be the most difficult to get right. However, when done correctly, it is by far the most concise of the options:
uid: htmlGrid
props:
  parameterGroups: []
  parameters: []
tags: []
component: f7-block
slots:
  default:
    - component: div
        style:
          display: grid
          grid-template-columns: 1fr 1fr 1fr
          grid-template-rows: 1fr 1fr
          grid-template-areas: >
            'cellA cellB1 cellC'
            'cellA cellB2 cellC'
      slots:
        default:
          - component: Label
              text: Cell A
              style:
                grid-area: cellA
                border: solid red
          - component: Label
              text: Cell B1
              style:
                grid-area: cellB1
                border: solid green
          - component: Label
              text: Cell B2
              style:
                grid-area: cellB2
                border: solid green
          - component: Label
              text: Cell C
              style:
                grid-area: cellC
Hello Justin,
thank you for your support.
I really appreciate this.
Your solutions are just what I was looking for.
In the next days I will test them and then I will close this topic probably.
Have a good Sunday
Wolfgang
