Only if the exception is thrown back into the Rule. It appears that in some cases the exception takes place in and is aught by the Rule Engine itself and instead of rethrowing the exceptions back up the stack trace and into the Rule it gets caught outside your Rule and the Rule gets terminated. And this problem is exacerbated by lambdas for some reason. I’ve seen, but not been able to study, that a exception that happens in a Rule can be caught in the Rule, but if it happens in the lambda it kills the Rule.
This is the root to why locks + lambdas + exception handling is such a dangerous thing in OH.
There are some times when a lock cannot be avoided, just like there are times where a lambda or a Thread::sleep cannot be avoided. But because of the way the Rules DSL works, all of these should be treated as a last resort. It is worth going to extraordinary lengths to avoid their use.
I’ll be the first to admit that there are some very significant problems with the Rules DSL. Error handling is perhaps its weakest point. I like the Rules DSL because it is easier for new users to become productive in it compared to more feature rich languages, but I would never ever recommend it for use in a “professional environment.” If you are used to and expecting something like that, I again implore you to use JSR223 instead.
Because of the limitations of exception handling outlined above, relying on exception handling in your Rules gives you a similar false sense of comfort. I think the counter argument is that the Rules DSL isn’t a processional environment. It’s not intended to be. And because of the limitations of exception handling one could make a good argument that within the Rules DSL using try/catch, and especially try/catch/finally would be an anti-pattern.
For the most part, the number of things that can cause an exception in a Rule is relatively low.
- The biggest one is type problems (e.g. an Item is NULL or UNDEF but the Rule just assumes it is a Number without checking first).
- The next biggest one is trying to parse a String to a Number or a DateTime that is not correct for that type.
- Next comes trying to sendCommand or postUpdate an invalid state to an Item (e.g. a Number > 100 to a Dimmer Item).
1 is the most troublesome because this exception usually just kills the Rule and cannot be caught.
3 is actually just a special case of 1.
I can’t think of others off the top of my head. I’m sure there are more. But all three of the above can be handled quite effectively by using standard defensive programming techniques (i.e. checking the type of an Item before you try to use it). And I believe both 1 and 3 can’t be caught in your Rule anyway. Your Rule will just stop.
We would welcome any contributions you can make to improve them.
There are also language features like arrays and classes which do not exist in the Rules DSL in the Xtend docs. Just because Xtend supports it doesn’t mean Rules DSL does.
Personally, I have high hopes for the Experimental Rules Engine. Not only does it introduce concepts that will make certain types of Rules really easy to create and it gives the non-technical users a nice UI based way to create Rules, but under the covers it appears to support JSR223 Rules. By default we can enter JavaScript in the UI but 5iver has discovered that the ERE can call Jython and I would assume Groovy written Rules as well. I’m hoping that a lot of these sorts of issues will simply go away.
