I’m in the process of adding 868Mhz to the binding rfxcom. To add ITHO CVE ECO RFT.
All goes well but when I want to build and test in Eclips I get the following error:
Resolution failed. Capabilities satisfying the following requirements could not be found:
[<<INITIAL>>]
⇒ osgi.identity: (osgi.identity=org.openhab.binding.rfxcom:jd2xx)
[org.openhab.core.io.transport.serial.javacomm version=3.4.0.202211140304]
⇒ osgi.wiring.package: (osgi.wiring.package=javax.comm)
[org.apache.karaf.kar.core version=4.3.7]
⇒ osgi.service: (objectClass=org.apache.karaf.features.FeaturesService)
[org.openhab.binding.rfxcom version=3.4.0.202211171437]
⇒ osgi.wiring.package: (osgi.wiring.package=jd2xx)
and when i load the snapshot into the folder addons of openhab I get:
15:46:20.458 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Amsterdam'.
15:46:20.467 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Location set to '52.421602562971586,4.645787911922841'.
15:46:20.467 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Locale set to 'nl'.
15:46:24.967 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
15:46:25.545 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
15:46:25.710 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
15:46:25.748 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.rfxcom [249]
Unresolved requirement: Import-Package: jd2xx
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
openhab-transport-serial is started
Anyone has any suggestions?
