The russound binding is now using the apache fluent api - which adds the following to my manifest.mf
org.apache.http.client;version="4.3.6",
org.apache.http.client.fluent;version="4.3.6",
However, when I create a jar and drop it into openhab2 (latest nightly build) - I get:
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.russound [193]
Unresolved requirement: Import-Package: org.apache.http.client; version="4.3.6"
All this works fine in the IDE. I’ve been dropping the version from the manifest.mf for those two packages as a workaround for now (which work fine). However, if I modify any file that uses those - the IDE adds the versioning back.
Is there a more permanent solution (like why isn’t 4.3.6 in the latest)?
