I recently received a RPI4_8G and wanted to test Openhab on it. I used the openhabian SD card image V1.5 with etcher but fails to boot on startup. The led warning codes learned me that I have an unsupported board type.
I could not find any explanation what an unsupported board type error means… Any ideas?
Because of that I started with some struggling manually installing everything.(Rasbian lite;Zulu java8, Samba,…) it works but with no linux experience I still have some features not working.
For this reason I would like to find out why the “hassle”-free setup isn’t working on my hassle -free RPI4
I use a Samsung SDXC 64gb card. Atm I don’t have another sdcard tot test with.
The image was likely based on an older version of Raspian Lite. @mstormi could confirm.
Install Raspian Lite and then install OpenHABian following the Linux installation instructions. Run openhabian-config and you basically have the same system.
Maybe it´s because it´s annouced as an Rpi4 with 8Gb Ram, which under normal circumstances would mean the same, but with more memory, which again, normally wouldnt call for a new kernel/OS.
(Normally in this case means computers in over-all (like a PC wouldnt call for a new OS/kernel just because of more memory added).
Hi all,
Saw this thread about a hassle free Pi4 8GB, never heard of one of them.
I have purchased one pi 4 and that’s the 4 GB and have had nothing but trouble with it and the Foundation seems to have washed their hands of it, offering hours of messing about trying to fix it.
Mine, still will not start with a powered hub plugged in, wifi only works if I put a dongle in it and it seems to be at times very sluggish and hard work and I still haven’t found any credible fix’s.
I have it in one corner of my office monitoring one thing, it’s nearer the door, next stop rubbish bin.
Give me a Pi3B+ any day of the week, smooth, fast and reliable.
I also have a Pi2B, excellent but for some reason now is giving me the error unsupported board ??? and after re-booting it has frozen on the rainbow screen with the combination of flashing 4 & 4 green light, sorry guy’s I’m not expecting a fix here just wanted to get that off my chest.
Stay well.
C.
