Items and groups that worked fine in 2.4 now generate warnings and errors in 2.5.
I suspect it has to do with QuantityTypes and Groups. Unfortunately I can’t identify the exact problem from the error messages.
I hope someone can help me.
2019-12-24 12:03:38.849 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'Wetter (Type=GroupItem, Members=6, State=NULL, Label=Wetterdaten, Category=sun_clouds)' about state update of item Solarstrahlung: Can not compare incompatible units.
java.lang.IllegalArgumentException: Can not compare incompatible units.
at org.eclipse.smarthome.core.library.types.QuantityType.compareTo(QuantityType.java:174) ~[bundleFile:?]
at org.eclipse.smarthome.core.library.types.QuantityType.equals(QuantityType.java:156) ~[bundleFile:?]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:260) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2019-12-24 12:03:38.850 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'Ps_Rrd4j (Type=GroupItem, Members=23, State=NULL, Label=RRD4J, Category=null)' about state update of item Solarstrahlung: Can not compare incompatible units.
2019-12-24 12:05:11.059 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@a2c66f' about state update of item Solarstrahlung: Can not compare incompatible units.
2019-12-24 12:05:11.062 [ERROR] [me.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: Can not compare incompatible units.
at org.eclipse.smarthome.core.library.types.QuantityType.compareTo(QuantityType.java:174) ~[?:?]
at org.eclipse.smarthome.core.library.types.QuantityType.equals(QuantityType.java:156) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.applyState(GenericItem.java:234) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.setState(GenericItem.java:219) ~[?:?]
at org.eclipse.smarthome.core.library.items.NumberItem.setState(NumberItem.java:121) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemUpdater.receiveUpdate(ItemUpdater.java:75) ~[?:?]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:52) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.lambda$0(EventHandler.java:155) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
2019-12-24 12:05:11.059 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'Ps_Rrd4j (Type=GroupItem, Members=23, State=NULL, Label=RRD4J, Category=null)' about state update of item Solarstrahlung: Can not compare incompatible units.
2019-12-24 12:05:42.057 [ERROR] [me.core.internal.events.EventHandler] - Creation of ESH-Event failed, because one of the registered event factories has thrown an exception: Error invoking #valueOf(String) on class 'org.eclipse.smarthome.core.library.types.QuantityType' with value '114.0 1/(m²·m²)'.
java.lang.IllegalStateException: Error invoking #valueOf(String) on class 'org.eclipse.smarthome.core.library.types.QuantityType' with value '114.0 1/(m²·m²)'.
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:189) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseType(ItemEventFactory.java:157) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.getState(ItemEventFactory.java:135) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.createStateChangedEvent(ItemEventFactory.java:130) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.createEventByType(ItemEventFactory.java:83) ~[?:?]
at org.eclipse.smarthome.core.events.AbstractEventFactory.createEvent(AbstractEventFactory.java:55) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.createESHEvent(EventHandler.java:134) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:108) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:85) ~[?:?]
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) ~[?:?]
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor82.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:180) ~[?:?]
... 10 more
Caused by: java.lang.IllegalArgumentException: unexpected token 8
at tec.uom.se.quantity.Quantities.getQuantity(Quantities.java:80) ~[?:?]
at org.eclipse.smarthome.core.library.types.QuantityType.<init>(QuantityType.java:95) ~[?:?]
at org.eclipse.smarthome.core.library.types.QuantityType.valueOf(QuantityType.java:138) ~[?:?]
... 10 more
The item definition, which probably concerns it, looks as follows:
Group Wetter "Wetterdaten" <sun_clouds>
Group Ps_Rrd4j "RRD4J"
Number:Temperature Temperatur "Temperatur [%.1f °C]" <temperature> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Temperatur:.*?\\s*(\\d+.\\d+)\\s*°C.*)]" }
Number:Dimensionless Luftfeuchte "Luftfeuchte [%d %%]" <humidity> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Luftfeuchte:.*?\\s*(\\d+)\\s*%.*)]" }
Number:Pressure Luftdruck "Luftdruck [%.1f hPa]" <pressure> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Luftdruck:.*?\\s*(\\d+.\\d+)\\s*hPa.*)]" }
Number:Speed Regenrate "Regenrate [%.1f mm/h]" <rain> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Regen \\(Rate\\):.*?\\s*(\\d+.\\d+)\\s*mm\\/h.*)]" }
Number:Speed Wind "Wind [%.1f km/h]" <wind> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Wind:.*?\\s*(\\d+.\\d+)\\s*km\\/h.*)]" }
Number:Intensity Solarstrahlung "Solarstrahlung [%d W/m²]" <solarplant> (Ps_Rrd4j, Wetter) { http="<[weatherCache:30000:REGEX(.*Solarstrahlung:.*?\\s*(\\d+)\\s*Watt\\/m².*)]" }
