I am trying to implement proxy items to deal with shelly’s total energy indication that are reset from time to time…
Here is what I came up with (script executed everytime an item for wich there is a proxy has a state change):
val _proxyItemToBeUpdated = org.openhab.core.model.script.ScriptServiceUtil.getItemRegistry.getItem(triggeringItemName + "_Proxy")
val increment = (newState as QuantityType<Number>) - (previousState as QuantityType<Number>)
if (increment > 0 ) {
val newValue = _proxyItemToBeUpdated.state as QuantityType<Number> + increment as QuantityType<Number>
postUpdate(_proxyItemToBeUpdated, newValue as Number)
I can get it to work if I first set newValue = increment as QuantityType once, then i can set newValue to currentState of proxy + increment as per the script above and it works, until openhab restarts, and the proxyItem value was restored from persistency and it seems I can’t cast it anymore to QuantityType when calculating the newValue.
I get this error :
2023-01-08 23:25:01.216 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'UpdateProxyItemsForCounters' failed: Could not cast 66.916 to org.openhab.core.library.types.QuantityType; line 13, column 18, length 51
It seems that somehow the restore from persistency does not get the state with its unit…
I’m a bit stuck at this stage… I have tried to add or remove casting in various places with no luck so far… Any recommendation on where I should look?
Thanks,
