Update 4.3.3 to 4.3.4 Javascript?
Using OpenHAB 4.3.3 within docker, all works fine with ECMAScript (ECMAScript 262 Edition 11) in rules and scripts
After Update to 4.3.4 i get some error like:
ScriptEngine for language ‘application/javascript’ could not be found for identifier: d3d8a1af-f4ac-4f66-9a6e-555aaa660137
ScriptEngine for language ‘application/javascript’ could not be found for identifier: 17aafb63-b454-4464-ab8d-33147aacb564
ScriptEngine for language ‘application/javascript’ could not be found for identifier: 27e0f40c-7a16-4134-909b-41c1f3aa89b5
ScriptEngine for language ‘application/javascript’ could not be found for identifier: 0175ab34-de69-46a7-b939-9764f6f22efc
ScriptEngine for language ‘application/javascript’ could not be found for identifier: b38a42b3-d919-4a7b-b555-bff9cb455484
ScriptEngine for language ‘application/javascript’ could not be found for identifier: 20c094cc-593c-49e8-8f6e-18cbe45dd614
What should i do? I am using from add on store JavaScripn Scripting ( This add-on provides support for JavaScript (ECMAScript 2022+) that can be used as a scripting language within automation rules. It is based on GraalJS from the GraalVM project.
When you do an upgrade the cache gets cleared. This means it must redownload and reinstall all the add-ons.
Sometimes this can take more time than it takes for OH to go from startlevel 0 to start level 40 where rules can start running.
Othertimes the installation of the addons can fail for various reasons.
  1. Wait a bit.
  2. If the errors keep happening try restarting OH and watch for errors installing add-ons messages in the logs.
  3. If there are errors installing add-ons or the errors persist, try Clear the Cache. Return to step 1 if necessary. If you get to step 3 again, something weird is going on.
thanks, I had two test script of older version of javascript!
After deleting and rebooting twice no errors …
