- Platform information:
- Hardware: Raspberry Pi 4B
- OS: Openhabian
- Java Runtime Environment: 11.0.18
- openHAB version: 3.4.4
Hi there,
after reading for a time and diving into the configurations I’m now trying to update a newly created item called “Tageswert_Erzeugung_Solar” from a MQTT item called “Solar_AC_Tagesertrag”. It’s the daily production value from my PV inverter, which grows over the day, has its maximum in the evening and starts with 0 the next day. I added the -non semantic- item that I wanted to fill by a rule each day at 23:55.
Is there a way to manage this via the rules GUI only, or have I to learn the code syntax and do it in the code section? When I’m putting in the “Solar_AC_Tagesertrag.state” variable or even “Solar_AC_Tagesertrag.state as DecimalType” in the state field of the rules mask it only takes the variables name as a text.
All the configurations I did until now were by use of the GUI (except mapping some textes to values) and I would prefer that method, if possible.
Regards
Michael
configuration: {}
triggers:
- id: "1"
configuration:
time: 23:55
type: timer.TimeOfDayTrigger
conditions: []
actions:
- inputs: {}
configuration:
itemName: Tageswert_Erzeugung_Solar
state: Solar_AC_Tagesertrag.state
type: core.ItemStateUpdateAction
