muere
(Reinhard Müller)
October 9, 2018, 6:43am
1
Raspi 3B
Installation: Openhabian
openHAB 2.4.0 Build # 1380
Aeotec Z-Stick Gen5
When updating with the config tool, the following error occurred:
dpkg: warning: openhab2: unable to stat config file ‘/var/lib/openhab2/etc/scripts/shell.colors.script’
(= ‘/var/lib/openhab2/etc/scripts/shell.colors.script’): Structure needs cleaning
dpkg: error processing archive /var/cache/apt/archives/openhab2_2.4.0~20181006154235-1_all.deb (–unpack):
unable to stat ‘./var/lib/openhab2/etc/scripts/shell.colors.script’ (which I was about to install): Structure needs cleaning
Errors were encountered while processing:
Updating FireMotD available updates count … 2018-10-08 19:51:44,749: FireMotD: Error: Template folder doesn’t exist. Upgrading from an older version? Please run make again or run the install function “FireMotD -I -v”.
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
What can I do?
Benjy
(Ben Clark)
October 9, 2018, 8:34am
2
This looks like file system corruption… Are you receiving any other strange errors?
What at the outputs of the following commands:
openhab-cli info
ls -l /var/lib/openhab2/etc
muere
(Reinhard Müller)
October 9, 2018, 8:56am
3
[08:36:28] openhabian@openHABianPi:~$ openhab-cli info
Version: 2.4.0-SNAPSHOT (#1380)
User: openhab (Environment Variable Set)
User Groups: openhab tty dialout audio bluetooth gpio
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhabian
OPENHAB_CONF | /etc/openhab2 | openhab:openhabian
OPENHAB_LOGDIR | /var/log/openhab2 | openhab:openhabian
URLs: http://192.168.178.28:8080
https://192.168.178.28:8443
[10:52:59] openhabian@openHABianPi:~$ ls -l /var/lib/openhab2/etc
ls: cannot access '/var/lib/openhab2/etc/org.ops4j.pax.logging.cfg': Structure needs cleaning
ls: cannot access '/var/lib/openhab2/etc/jetty.xml': Structure needs cleaning
total 232
-rw-rw-r-- 1 openhab openhab 1035 Oct 4 00:12 all.policy
-rw-rw-r-- 1 openhab openhab 1067 Oct 4 00:12 branding.properties
-rw-rw-r-- 1 openhab openhab 1067 Oct 4 00:12 branding-ssh.properties
-rw-rw-r-- 1 openhab openhab 10 Oct 4 00:12 com.eclipsesource.jaxrs.connector.cfg
-rw-rw-r-- 1 openhab openhabian 59 Sep 29 10:06 com.eclipsesource.jaxrs.swagger.config.cfg
-rw-rw-r-- 1 openhab openhab 12924 Oct 4 09:01 config.properties
-rw-rw-r-- 1 openhab openhab 318 Oct 4 00:12 custom.properties
-rw-rw-r-- 1 openhab openhab 459 Oct 4 00:12 custom.system.properties
-rw-rw-r-- 1 openhab openhab 1144 Oct 4 00:12 distribution.info
-rw-rw-r-- 1 openhab openhabian 4616 May 28 10:33 equinox-debug.properties
-rw-rw-r-- 1 openhab openhab 1704 Oct 1 17:16 host.key
-rw-rw-r-- 1 openhab openhabian 252 May 28 10:33 java.util.logging.properties
-?????????? ? ? ? ? ? jetty.xml
-rw-rw-r-- 1 openhab openhab 1664 Oct 4 00:12 jmx.acl.org.apache.karaf.bundle.cfg
-rw-rw-r-- 1 openhab openhab 3316 Oct 4 00:12 jmx.acl.org.apache.karaf.config.cfg
-rw-rw-r-- 1 openhab openhab 20084 Oct 4 00:12 jre.properties
-rw-rw-r-- 1 openhab openhabian 2091 May 28 10:33 keys.properties
-rw-rw-r-- 1 openhab openhabian 604 Sep 29 10:06 keystore
-rw-rw-r-- 1 openhab openhab 493 Oct 4 00:12 org.apache.felix.eventadmin.impl.EventAdmin.cfg
-rw-rw-r-- 1 openhab openhab 371 Oct 4 00:12 org.apache.felix.fileinstall-deploy.cfg
-rw-rw-r-- 1 openhab openhab 1737 Oct 4 00:12 org.apache.karaf.command.acl.bundle.cfg
-rw-rw-r-- 1 openhab openhab 2025 Oct 4 00:12 org.apache.karaf.command.acl.config.cfg
-rw-rw-r-- 1 openhab openhab 1156 Oct 4 00:12 org.apache.karaf.command.acl.feature.cfg
-rw-rw-r-- 1 openhab openhab 1154 Oct 4 00:12 org.apache.karaf.command.acl.jaas.cfg
-rw-rw-r-- 1 openhab openhab 1219 Oct 4 00:12 org.apache.karaf.command.acl.kar.cfg
-rw-rw-r-- 1 openhab openhab 1376 Oct 4 00:12 org.apache.karaf.command.acl.scope_bundle.cfg
-rw-rw-r-- 1 openhab openhab 1118 Oct 4 00:12 org.apache.karaf.command.acl.shell.cfg
-rw-rw-r-- 1 openhab openhab 1384 Oct 4 00:12 org.apache.karaf.command.acl.system.cfg
-rw-rw-r-- 1 openhab openhab 2705 Oct 4 00:12 org.apache.karaf.features.cfg
-rw-rw-r-- 1 openhab openhab 3724 Oct 4 00:12 org.apache.karaf.features.repos.cfg
-rw-rw-r-- 1 openhab openhab 834 Oct 4 00:12 org.apache.karaf.jaas.cfg
-rw-rw-r-- 1 openhab openhab 532 Oct 4 00:12 org.apache.karaf.kar.cfg
-rw-rw-r-- 1 openhab openhab 758 Oct 4 00:12 org.apache.karaf.log.cfg
-rw-rw-r-- 1 openhab openhab 4151 Oct 4 00:12 org.apache.karaf.shell.cfg
-rw-rw-r-- 1 openhab openhabian 33 Sep 29 10:06 org.eclipse.smarthome.audio.cfg
-rw-rw-r-- 1 openhab openhabian 22 Sep 29 10:06 org.eclipse.smarthome.voice.cfg
-rw-rw-r-- 1 openhab openhab 65 Oct 4 00:12 org.jupnp.cfg
-?????????? ? ? ? ? ? org.ops4j.pax.logging.cfg
-rw-rw-r-- 1 openhab openhab 4446 Oct 4 00:12 org.ops4j.pax.url.mvn.cfg
-rw-rw-r-- 1 openhab openhabian 1346 Sep 29 10:06 org.ops4j.pax.web.cfg
-rw-rw-r-- 1 openhab openhab 0 Oct 4 00:12 overrides.properties
-rw-rw-r-- 1 openhab openhab 9105 Oct 4 00:12 profile.cfg
drwxrwxr-x+ 2 openhab openhabian 4096 Oct 4 09:01 scripts
-rw-rw-r-- 1 openhab openhabian 1848 May 28 10:33 shell.init.script
-rw-rw-r-- 1 openhab openhab 814 Oct 4 00:12 startup.properties
-rw-rw-r-- 1 openhab openhab 5316 Oct 4 00:12 system.properties
-rw-rw-r-- 1 openhab openhabian 1525 Sep 29 10:06 users.properties
-rw-rw-r-- 1 openhab openhab 447 Oct 4 00:12 version.properties
[10:53:44] openhabian@openHABianPi:~$
Benjy
(Ben Clark)
October 9, 2018, 9:40am
4
As I thought, there is file system corruption in these folders. Are you running off an SD card, or a USB hard-drive?
muere
(Reinhard Müller)
October 10, 2018, 6:45am
6
Remains only a new installation?
muere
(Reinhard Müller)
October 10, 2018, 11:47am
7
Now I do not understand anything anymore.
I removed the SD and plugged it in again. After a reboot, I was able to access the terminal:
Now: Update openHAB 2.4.0 Build # 1386.
With ls -l / var / lib / openhab2 / etc there are no more errors.
The password “openhabian” works in the terminal.
In the browser now comes a login window and there is a password required, but that of the terminal does not work.
5iver
(Scott Rushworth)
October 10, 2018, 12:19pm
8
muere
(Reinhard Müller)
October 11, 2018, 10:14am
9
Thanks, after the downgrade it works again.
Benjy
(Ben Clark)
October 11, 2018, 11:01am
10
Good to hear you got it working! Now that you have, it might be a good time to create a backup of openHAB to save off of the SD Card.
muere
(Reinhard Müller)
October 11, 2018, 11:12am
11
I thought so too.
I have already saved my items, sitemaps and rules.
Is there an optimal backup solution?
Benjy
(Ben Clark)
October 11, 2018, 2:51pm
12
openhab-cli backup <filename>
will create a backup of all openHAB configuration files which can be restored with openhab-cli restore <filename.zip>
. For a backup of more than just this, openHABian comes with Amanda .
